Easier method is to fill the crack on the outside where the pepples collect with a clear silicon caulk. No more pepples and problem solved.
good link I was going to do this myself
Thanks to all for the replies !... will be doing this over the next week.
Originally Posted by jwmgr8
(Post 1583213141)
The foam goes in the rear wheel well. You can feel the gap between inner and outer fenders .Fill with weather striping foam. it will keep rocks out. No need to take wheel off.
Someone referred to TSB- if there is one post number?? someone else mention black silicone cutting a hole?? better description is needed. The guy that suggested using silicone was talking about cutting a small hole in the tip of the silicone tube - no hole drilling needed on the car. Just apply a seam of silicone right where the pebbles accumulate. Not sure why he recommended black silicone (unless you have a black car). I used clear silicone. |
Originally Posted by dmuellenberg
(Post 1583216715)
I'm pretty sure there was never a TSB on this since all C6 models have this issue and was never fixed. They wouldn't issue a TSB just for removing the pebbles.
(Post 1583217972)
Problem with using silicone is the rocks still get into the fender, you just can not see them. The weather stripping method keeps the rocks from getting into the fender cavity. Also I think this is only a problem with wide body cars Z06, GS & ZR1. GM did not change inner fender design for wide body. Would have been nice if it did not need fix? maybe C7 is the fix.
(Post 1583209073)
What TSB is that? I've never heard of or seen it.
INFORMATION
Bulletin No.: 11-08-65-001A Date: June 22, 2011 Subject: Information on Small Rocks, Sand and Gravel (Road Debris) Trapped Between Quarter Panel and Rocker Panel and Installing Adhesive Back Shim Stock Models: 2005-2011 Chevrolet Corvette Built Prior to VIN Breakpoint B5107578 Supercede: This bulletin is being revised to update the repair information. Please discard Corporate Bulletin Number 11-08-65-001 (Section 08 - Body and Accessories). Some customers may comment that road debris has found its way in between the outer quarter panel and rocker, and is visible in the gap between the two panels. This condition may be caused by debris being carried up by the tires and collecting in the gap between the panels. An example of this condition is shown in the grap [...] |
Quick can you post the rest of the TSB? Couldn't find it on google.
I opened up the quarter panel last night, wow was it dirty! Gonna go buy some weather stripping. |
It works, did the foam insert on my Z07 and no more problems. :thumbs:
Originally Posted by wolf8218
(Post 1583225996)
I opened up the quarter panel last night, wow was it dirty! Gonna go buy some weather stripping. http://forums.corvetteforum.com/alld...engineid=4047/ |
(Post 1583216715)
Originally Posted by zeeohh6ex
(Post 1583230742)
My car is at the dealer now I told them about the problem and they said they found the TSB and fixed it for me. I'm going to pick it up today.
I have a copy of the tsb but I can't post it showing the illustrations contained in it. If anyone here can post it, pm me your email and I'll get a copy to you.
Originally Posted by 3X2
(Post 1583234293)
Just did this last week. Just undo 3 small bolts and shake/blow them out and then put a small bead of clear silicon to help prevent it from happening again.
4 Attachment(s)
Some one should save these, I don't know how long imgur will host images.
Attachment 48377188 Attachment 48377189 Attachment 48377190 Attachment 48377191 |
Thank you Wolf!
+1 good stuff
You're welcome.
Personally I think this solution is better: http://www.nakidparts.com/id22.html I just used some weather stripping from Home Depot to fill in the gap from the wheel well to the quarter panel. This would eliminate the source of the rocks, rather than just stopping them from falling all the way down to your lower sill. If you follow the TSB you'll have about 5 lbs of rocks accumulate inside your panel. Doesn't seem kosher to me. |
