pebbles in lower sill
Hello..does anyone have a easy way to remove the small pebbles that gather between the lower rocker sill and the rear quarter panel ??
Undo the few bolts that hold the rear fender liner by there and then just blow/shake them out.
Originally Posted by Unreal
(Post 1583208054)
Easy to get out
Just be careful pulling fender out Long term fix is filling inner fender gap with body. I used large cell foam rubber you can get at any hardware store. about 1 inch sq |
After you blow the pebbles out get some black silcone and cut a small hole in the tip and squease some in from front to rear. put everything back together and no more pebble problem. Let the car sit for about a day to give the silicone a chance to dry abit and you're good to go.
There is a TSB so if you are under warranty the dealer can fill the gap for you.
Originally Posted by Dutchman9900
(Post 1583208165)
Originally Posted by Joezone914
(Post 1583208234)
I would like to see a DIY on this. Not sure exactly where to put the silicone... Thanks.
Originally Posted by dmuellenberg
(Post 1583209073)
What TSB is that? I've never heard of or seen it.
Link to a non-supporting vendor deleted.
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (address, phone number, e-mail address, URL, price, part number, offer to send contact information via PMs, etc.) or so frequent that they become marketing and promotional references. |
Excellent illustration. When the weather breaks, its the first thing I'm doing. Thanks for the posting! :cheers:
^interested in the deleted info/photos removed above.
When the you remove the rear tire, you can get into the wheel well and see the gap that allows the small rocks in. I don't like the black silicon idea, but it works. Used some readily available foam from the hardware store and cut it to size to fill the gap.
Please PM me the removed pictures. Thanks
(Post 1583208234)
(Post 1583208165)
Originally Posted by jwmgr8
(Post 1583208136)
Easy to get out
Just be careful pulling fender out Long term fix is filling inner fender gap with body. I used large cell foam rubber you can get at any hardware store. about 1 inch sq Someone referred to TSB- if there is one post number?? someone else mention black silicone cutting a hole?? better description is needed. |
Pics of this would be greatly appreciated.
where is the tsb?
