C6 wheels tires on my C5
1 Attachment(s)
I tried 2 sets and they both worked fine, both sets have the stock C6 tires. if you went wider than the 285/35/19 in the rear I could see how you would have problems with the inner tire would rub the inner fender lining. i can stick my finger between the tire and the inner fender lining.
the Hancock Evo v12 tires ride so much better and quiter that the Goodyear run flats. |
No offense but that doesn't look good at all. The rear wheel is in to far and the fender gap is huge. Maybe if you lowered it but IMO its not a good fit.
they make spacers to fix that problem
read this thread http://forums.corvetteforum.com/c5-t...s-on-rear.html |
Originally Posted by GTJim
(Post 1583130471)
Originally Posted by derek502
(Post 1583131135)
i do plan to lower the rear a little bit, the fender gap is the same as the C5 wheels/tires.
I just did this but used the spacers for the rear and also a 1/4" spacer for the front. They fit perfectly.
http://i29.photobucket.com/albums/c2...ps5e335e84.jpg |
Originally Posted by Abnmarine
(Post 1583131611)
I just put the same wheels on mine and used a 1 inch spacer on the rear. Worked perfect! Got it from these guys. :thumbs:
http://www.motorsport-tech.com/4DCGI/wheel_adapters |
Next week I'm going to lower it.
http://i1239.photobucket.com/albums/...ps4fe9b455.jpg |
Originally Posted by andrec10
(Post 1583132438)
Can you tell me what Spacer you ordered for the rear? Link maybe?
It took me a few times
Having it lowered then raised again before I come up with this look....
Without it bottoming out ... http://i1358.photobucket.com/albums/...ps02af6a28.jpg |
