TOBASCO |
03-03-2013 01:25 PM |
Works fantastic. I've used a leaf blower in the past. Does it work - of course. But it is about a 3 on a scale of 10 compared to the Master Blaster.
If you want speed of completion, powerful focused air handling, ability to get all the water out of nooks and crannies fast, provide warm air, and is very easy to use, it's everything you're hearing about it.
Just about the only downside to it is that is does draw a lot of power (which is why it works so well) - so I would definitely recommend a dedicated outlet for its use. I had it on the same line as a deep freezer in the garage and it typically blew a fuse with each use. Now, no problems.
