Aluminium Control Arms Tubular Steel Lowers Coilovers 68-82
Aluminum Upper Control Arms for 63-82 Corvettes: Natural Finish, Performance Ball Joints
Aluminum control arms greatly improve your suspension geometry which directly translates into improved handling and cornering ability. This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms. Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings! Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle. Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints. MADE IN THE USA! |
Aluminum control arms greatly improve your suspension geometry which directly translates into improved handling and cornering ability. This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms. Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings! Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle. Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints. MADE IN THE USA! http://www.xplosiveperformance.com/A...ts_p_1932.html http://www.xplosiveperformance.com/t...axx=300&maxy=0 $765.95 https://www.corvetteforum.com/forums...ser_online.gif https://www.corvetteforum.com/forums...ons/report.gif https://www.corvetteforum.com/forums...c/progress.gif |
copy ,paste, repost, ......copy ,paste, repost,
if you truly want the public to pay attention to your product. Do something other than copy,paste, repost, ....any monkey can do that. maybe some installed pics, maybe 3-4 words in English, so we know this is not some automated sales spam. look at some of our best customer service venders like Wilcox, Dewitts. they all are active contributing members , that explain, and guide the people how to use their products. |
Aluminum control armsgreatly improve your suspension geometry which directly translates into improved handling and cornering ability. This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms. Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings! Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle. Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints. MADE IN THE USA! |
Aluminum control armsgreatly improve your suspension geometry which directly translates into improved handling and cornering ability.This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms. Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings!Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle.Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints. MADE IN THE USA!
look great, but a lot of posts....
