vinyl wrap
Hey--
I saw a thread on this about 1 1/2 years ago in this forum but no one had ever tried doing it to a c3 at that point. My question is, has anyone tried it now? My 72 has a deteriorating paint job up front, basically it needs a repaint but that's probably 3 years away I'm guessing due to the 5k to 10k price tag. I had forgotten about the vinyl wrap diy option until today, and it looks like they've got some nice colors that would work. But before I would even attempt to undertake something like that, I'd like to know if anyone else had ever took a shot at it. Thanks |
I saw an episode of "How Do They Do That" not too long ago where a Union Jack wrap was applied to a Lotus Exige. Don't recall the cost, but I'd think a C3 shouldn't be any more difficult for a real pro shop.
:cheers: |
I think wrapping a c-3 would be pretty str8 forward , except the rear deck and quarter panels , there you will need one real big section of wrap because there are no breaks in the surfaces. Well at least on my 1980 there are not any .
I put a wide vinyl stripe on my hood/rear deck and found the process to be rather difficult...dealing with the curves/humps on the car and keeping the air bubbles out of it. I wouldn't want to attempt doing the whole car without a lot of help from experienced folks.
If you want it done right, you'd best just take it to a business that does this all the time. It will be costly [not as much as a paint job] and it won't last more than a few years, unless you keep it coated with a UV filtering coating like Nu-Vinyl or Meguiar's protectant for plastics. Zaino (a polymer polish) might also block UV and still keep the surface shiny. I think you would get the best prices in a large metropolitan area where there is a bigger market for this stuff. Keep us "in the loop" if you do more research or actually have it done. |
The new wrap is very easy to work with air bubbles are easy to eliminate with the newer 3M wrap.. It is designed specifically to deal with air bubbles.. I just think that rear quarter area and back deck would be a problem because you would need a sheet way bigger then is sold on line.
Also be aware than any little surface defect...bump, nick, pit, bubble...will show up just as badly when covered with a vinyl surface. It will NOT hide defects, unless you prepare them properly [filling, sanding, etc.] before installing it.
Look into Plasti-Dipping the car. Should get you by until you're ready to paint, and it'll probably be a lot cheaper than wrap.
How hard is it to remove Plastic Dip when you are ready for paint??? Thanks, PW
I'd suspect "they" make wrapping a curvy body look a lot easier than it actually is...
Originally Posted by CaptPaul
(Post 1583031625)
Well, according to this vid, it's looks fairly straightforward. |
I have worked with vinyl graphics and a wrap is not as easy as it looks, but if you pay to have it done is no big deal for installers. i would not recommend tackling it yourself because you may be out the $$$ invested on the vinyl. my $.02
I know I wouldn't attempt it but it does look pretty cool!
https://www.dipyourcar.com/home.php. Looks pretty easy and a color change in an afternoon. Something to consider if you don't have the $5-8K for a full on strip and paint.
I did 2 stripes on the fender like the new grand sports and that was challenging. Took about 2 hours and it wasn't flawless. I would not even think about attempting the whole car.
Originally Posted by briankeery
(Post 1583030897)
Sorry in advance if this offends anyone! |
Can do some amazing stuff with wraps, but they do "wear out" quicker than paint.
I know this isn't a Corvette, but I found the color to be pretty amazing. Got me thinking that our '77 would be a good promotional car for my business. Not talking about putting words all over it, just a color that works. The color you see below is seriously being considered. http://www.dgermancar.com/wp-content...-rear-view.jpg |
I used vinyl wrap in another car and, depending on your objective, it may be a viable alternative but keep in mind that over time (time, weather and exposure), the vinyl will lift where folded, even if it is professionally applied. In my case, I used it as an accent on the hood and trunk and eventually replaced the vinyl with paint. Turned out to be an expensive exercise.
