-   C5 Forced Induction/Nitrous (https://www.corvetteforum.com/forums/c5-forced-induction-nitrous-86/)
-   -   *CLOWNS AES 390 Build* (https://www.corvetteforum.com/forums/c5-forced-induction-nitrous/3209538-clowns-aes-390-build.html)
Blitzkrieg 01-29-2013 09:30 PM
Well fellas I have decided to build a solid foundation before I blow up my stock motor.
- AES 390 LQ9 Short block, 10.0 CR, Callies C-Series crank and Compstar H beam rods, Diamond pistons with steel rings, mellings high volume oil pump, LS3 oil pan.
- Pro Comp 280cc 70cc CNCd LS3 heads, PRC Double springs, SS Valves, LQ9 gaskets, LS3 Rockers with Comp Trinions, stock LS7 lifters, ARP studs.
- ECS Novi 2000 3.0 pulley, IW 10% OD 8 rib and DP Direct Drive.
- FIC 1000s, AR 2" Headers no cats, Alkey Control Duel Meth #15/ #10
- Aruns Cam pick- 230/242 .609/.615 115 lsa ( Stage III )
- LS3 Ported Intake, LS2 TB, RX Monster catch can.
- EFI Live and LC-1 wideband, Doug Ring tune (ECS)
Motor is at AES and the old motor is coming out mid March. New Motor will be done April 1st, Tuning mid to late April!:thumbs:
http://i1024.photobucket.com/albums/...ps949fe8d8.jpg
http://i1024.photobucket.com/albums/...ps4d7d23d0.jpg
http://i1024.photobucket.com/albums/...psd488e72f.jpg
http://i1024.photobucket.com/albums/...ps7e177ca5.jpg
http://i1024.photobucket.com/albums/...ps8b61594f.jpg
http://i1024.photobucket.com/albums/...ps33b86092.jpg
http://i1024.photobucket.com/albums/...ps479d3a8e.jpg
http://i1024.photobucket.com/albums/...ps819da197.jpg
http://i1024.photobucket.com/albums/...psf2e34177.jpg
http://i1024.photobucket.com/albums/...ps4944f702.jpg
Yellow03Z06 01-29-2013 09:35 PM
That motor won't clown around!
breecher_7 01-29-2013 09:40 PM
I believe there 390ci engines use a C - series crank, a 5140 forging. Not a 4340 forging like the compstar. You said "comp" crank, that's where my confusion comes in. Should go good if those heads don't just fall apart or crack while your torquing them down!
4DRUSH 01-29-2013 09:44 PM
Very Cool
2 questions
1. Does the Dallas direct drive bolt up to an iron block 100%
2. What does the RX monster can look like & how is it plumbed
(thinking you'd be better off with a big remote breather catch can, maybe 2)
2003VETT 01-29-2013 09:45 PM
Good luck with the build Brian... Sounds like it will be a beast...
Blitzkrieg 01-29-2013 09:49 PM
Originally Posted by 4DRUSH (Post 1582982283)
Very Cool
2 questions
AES will have to drill and tap a hole on the right side of the iron block, All LS blocks have this hole already! They have done this for a few motors already!
I don't have a pic of the Monster can but it is huge, I have not got that far as far as the routing of the lines, but RX states there can works for big boost!
That was a very nice post Jay, didn't know you had it in you!:thumbs:
breecher_7 01-29-2013 09:50 PM
The direct drive will not just bolt up to the block. The lq9 block only has one of the bolt holes of the 3 on the bracket. There is a boss on the block for a second of the 3, it will need to be drilled and tapped. There is no provision for the third and upper bolt next to the timing cover. You can either fab a bracket and run to a timing cover bolt or just forget about the 3rd bolt. It's plenty stron with the two and does not flex at all.
Very Cool
2 questions
Blitzkrieg 01-29-2013 09:52 PM
Thanks Tony, I changed it, it is a C- Series crank! And thanks for concern on the heads man!:thumbs: If they fail in any way, I'll slap on some LSAs.
robert miller 01-29-2013 10:50 PM
Very Cool
2 questions
2. The can is plumbed center line of the can going to the driverside rear valve cover outlet. Then one of the outer lines going to the vacume line just behind the T.B.on the intake. Then the other outer line on the other side of the can goes into the pipe about six inches infront of the blower. :thumbs:
Robert 2000 01-29-2013 10:56 PM
Funny that your engine would be done on April Fools day :lol:
Seriously tho I wanna see what this thing is gonna do when it is all done. Nice looking build you have going :cheers:
Milan 01-29-2013 11:16 PM
We have the same cam...cool! What IM are you using?
Blitzkrieg 01-29-2013 11:35 PM
Originally Posted by milan (Post 1582983076)
we have the same cam...cool! What im are you using?
im ?
ajrothm 01-29-2013 11:43 PM
Looks like a SOLID build plan.... Should make some serious power..
JDS99 01-29-2013 11:57 PM
Good stuff :thumbs:
If you're dropping the engine in, make sure to clearance the passenger's side motor mount bracket before dropping the engine in. The LQ9 has a threaded boss in the way that you won't need. Ask me at what point I figured that out when I dropped mine in.. :crazy:
Good call on the LS3 oil pan. I did the same and was able to drop the 402 in from the top, with SFI bellhousing on, and stab the clutch and pilot without ever dropping the cross-member 1mm. :smash:
AES may be doing it already, but have them drill and tap the extra oil pan bolt hole while their at it
Good luck and enjoy the build man. :cheers:
fotoboy 01-30-2013 12:41 AM
Very cool, what are your hp goals?
helga203 01-30-2013 06:49 AM
Me likey.:yesnod::yesnod::thumbs::thumbs:
Blitzkrieg 01-30-2013 08:23 AM
Originally Posted by JDS99 (Post 1582983328)
Good stuff :thumbs:
The motor is coming out the bottom, sorry for saying "drop new motor in", It will be much easier to get the headers in as well!
I like the idea of an extra oil drain plug, thanks for that tip!:thumbs:
GAMEOVR 01-30-2013 08:25 AM
That car should run it's ass off literally. Good luck on the build and have fun. :thumbs:
Blitzkrieg 01-30-2013 08:30 AM
Well my goal would be 1000hp! However I 'm pretty sure that my Novi 2k will be more than maxed out with 3.0, DD and 10% OD and I'm not changing head units so 1000 is out of the question.:lol:
According to a few members the 2k max is 900-950 if I'm lucky. Doug is tuning the car and whatever he is able to get out of it I guess thats what it will be! I am hoping for 900, anything after that will be a bonus! :thumbs:
lghtsout 01-30-2013 08:32 AM
Good Luck with the build Clown:rock:
