Procharger Bid Red Valve Enclosed or Open?
I wanted to get everyones opinion on open vs closed Procharger Bypass Valve. It seems allot are running the open version. I am concerned about all the dirt it would be sucking into the engine. I purchased the open version and need to decide if I should sell it to get the enclosed version. It is mounted just inside the drivers side inner fender.
http://i36.photobucket.com/albums/e1...miahj/BOV3.jpg |
open ftw.dirt can't get in.car running bov is blowing air out all the time,when you go in boost it closes.when car is not running it is closes.dirt can not get in
This is a Bypass Valve. It is pulling air in until boost come on. Then it closes.
my is a blow off valve.spring closed and vacuun opens it.car running in vacuum supercharger is making wind and pushing air out.car cant pull any air on any of charge pipes
If you have ever heard the big red you will know that thing pushes air out like a freaking jet engine. No worries on the dirt
It's only called open do to the fact the air comes out all the way around the top.top is basicly open,air goes every direction.closed big red directs air through the big port....btw the bottom part is the same,same valve,spring,coupler and all.just the peice that on top is different
Is there any particular reason this couldn't be used with a Vortech system?
Any benefits to it besides the noise? How is this one compared to the one A&A sells, the Mondo valve? |
I just know that on my last two systems that had bypass valves with filters on them. I would have to clean the filter from time to time. If I run this Big Red there is nothing to filter the air when it is open.
Is there any particular reason this couldn't be used with a Vortech system? Any benefits to it besides the noise? How is this one compared to the one A&A sells, the Mondo valve? |
Just to reiterate, the air goes OUT of the valve, not in.
Think of it like your exhaust....you wouldn't put a filter on that would you? Big red is an awesome BOV. But it's going to be LOUD. Definitely ride in a car with one before you decide to run it. I took my friend's Silverado SS to get emissions tested, he has a D1SC and a big red, when I fired up his truck it scared the **** out of the emissions guy. |
Originally Posted by JeremiahsC5
(Post 1582949249)
If the above valve is used on a supercharged application. Air is always going out. NEVER in. You can call it what you like, but it's still doing the same thing. |
I have the same one and it is very loud and works great!
I believe the filter is there to reduce the noise, not fiter anything.
ttt
p.m. to you man on the BOV...Robert
I love the sound. I want the car to be obnoxious. I just do not want trash sucked into the engine. If it is never pulling air in then I am ok with using it.
