First Impressions After Lowering, Pfadt Shocks and Sway Bars....
Ok, before anyone says it. Yes, I said many times that I would not lower my vette......shut up.
On Thursday I had the Johnny O'Connell Stage 1 shocks and sways installed and had my vette lowered on the "stock bolts" at the same time. I have driven the car about 30 miles since the work was done. (At 100-200 miles I plan to get an alignment). The ride is more firm and a little more bouncy, but nothing uncomfortable. Being that it is so cold here right now, it takes a while to warm up your tires, so no real fast corners yet. But on an interchange that is basically a large circle the car felt much more planted. I'm sure it'll settle a bit more, but I didn't want to be accused of starting a thread that was worthless without pics. LOL http://i5.photobucket.com/albums/y17...1_19_13__1.jpg http://i5.photobucket.com/albums/y17...1_19_13__2.jpg http://i5.photobucket.com/albums/y17...1_19_13__3.jpg http://i5.photobucket.com/albums/y17...1_19_13__4.jpg http://i5.photobucket.com/albums/y17...1_19_13__5.jpg :D |
Looks really good!
\:cheers: |
Originally Posted by 91LSMAN
(Post 1582887205)
Is that really lowered? Looks like the factory height. Your car is fully settled already. It only takes a couple hard stops and launches to settle it down. I'm about to go with their Featherlight coilovers. I thought about trying the shocks but they are for factory height cars and I have mine almost as low as you can go in the front with C6 front bolts and longer rear bolts. I went as low as I could without scraping everything down the road. Trimmed an inch off the air dam too. My C6 Z06 shocks bottom out all the time so I figured these wouldn't work either since they have the exact same travel as OEM shocks do. Here is the description from their site.
"These Johnny O'Connell Shock upgrades are the only OEM quality replacements on the market. Made to the exact travel and durability requirements as the OEM shocks, these upgraded versions have a completely revised damping curve engineering into them. These shocks accomplish 2 things: One is that they remove the harsh ride characteristics associated with the OEM dampers, when at speed on a highway or hitting a bump in a middle of a turn. The other is that they are stiffer in performance applications like quick turn in to get the car planted in a turn, and transient handling moves from left to right and visa versa. These shocks are a "set it and forget it" solution that you can bolt on to your Corvette and know that it was tuned by Johnny and Pfadt to the exact specifciation it needs to be for a perfect performance and smooth ride balance. These shocks will work for all models of C5/C6 Corvettes" |
Originally Posted by IRON MAIDEN
(Post 1582887317)
"These Johnny O'Connell Shock upgrades are the only OEM quality replacements on the market. Made to the exact travel and durability requirements as the OEM shocks, these upgraded versions have a completely revised damping curve engineering into them. These shocks accomplish 2 things: One is that they remove the harsh ride characteristics associated with the OEM dampers, when at speed on a highway or hitting a bump in a middle of a turn. The other is that they are stiffer in performance applications like quick turn in to get the car planted in a turn, and transient handling moves from left to right and visa versa. These shocks are a "set it and forget it" solution that you can bolt on to your Corvette and know that it was tuned by Johnny and Pfadt to the exact specifciation it needs to be for a perfect performance and smooth ride balance. These shocks will work for all models of C5/C6 Corvettes" A funny thing today ,I haven't put a lot of miles on mine since having it lowered with the aftermarket bolts , but after today and after giving the car a beating a few times it had a bounce to it .... Nice to know that modding will never stop ... It's not about the money anymore that went out the window a year ago |
Looks good!!!!:rock:
Originally Posted by jetmech
(Post 1582887249)
Looks really good!
\:cheers: |
Took mine a couple weeks to take a final set after lowering it on the stock bolts. And it's a daily driver.
After market bolts ,
She's pretty low ....http://i1358.photobucket.com/albums/...ps98cc56e8.jpg
(Post 1582887317)
Is that really lowered? ....
Here is a shot in the same spot right after wheel installation http://i5.photobucket.com/albums/y17.../8-25-12-3.jpg I don't want a "slammed" look. It's my only car and the roads here can get pretty bad sometimes. I've heard a lot of different opinions as far as how long it takes to settle. I can also tell it is lowered because I had to stretch more when cleaning the bottom of the sides. LOL I took a few measurements before everything was done and in a couple weeks I'll take new ones and see how much it dropped. THANKS ALL!!! |
(Post 1582887954)
Yes.
Originally Posted by James2002z06
(Post 1582888023)
Brother , get off the gas man ...your car looks great love the color , you think
LOL |
OP, car looks great, I can tell it looks lower:thumbs:
Originally Posted by Silverback51
(Post 1582887796)
That is a great-looking car. Keep us informed on the Pfadt gear. I have just installed their transmission mount and I was thinking of getting the JO'C kit as my next addition!
(Post 1582888050)
What?
LOL |
Originally Posted by Roc87
(Post 1582888098)
OP, car looks great, I can tell it looks lower:thumbs:...
Originally Posted by geksegqu
(Post 1582888137)
What a great car,keep up the good work...
Originally Posted by Wadoka
(Post 1582888173)
(Post 1582888211)
Those are or were words from my 22 year old daughter , get off the gas daddy... I'm sure it's cool , lol
Nice upgrade and your car looks great. :thumbs:
Looks really good man! :cheers:
WOW, that thing must have been a 4x4 before you lowered it? It does look nice but I would go even LOWER! :D
(Post 1582888952)
Originally Posted by 'Shifter
(Post 1582895546)
Originally Posted by Todds9
(Post 1582895963)
No it's not getting Lower. LOL (except for anymore that it settles.) :thumbs: |
