Another newbie question.....
Hello again everyone -
I have another rookie question. When a C4 (1996) left the factory, what color was the outside of the floor pan?.....I'm referring to the area facing the ground that hangs slightly below either side of the center supports. (the brake lines run along-side of it, front to rear) Just wondering if it's supposed to be black, primer, or color-keyed to match the exterior paint color of the car. As always, thanks for your time ! nummy |
depends..some had a coating...some not. Some dealerships applied their own sound deadening/insulating material. Never seen one color matched to the body.
Originally Posted by nummy
(Post 1582879747)
Just wondering if it's supposed to be black, primer, or color-keyed to match the exterior paint color of the car. Wow, that's a good question. I don't know :leaving: IIRC there's some body color overspray on the sides of the pan of mine - at least I think it was just overspray and not GM trying to paint them. I'd be interested in the answer to this too :lurk: |
It seems like the entire outer surface of the floor pan (SMC or fiberglass?) is already tinted red, and not overspray....if that's even possible.
Not sure how the C4 was assembled in its day, but I assumed all the body panels were prepped and painted prior to being attached to the car itself, so I'm not sure where over-spary would even come in contact with the floor pan......but then what do I know, I'm a rookie ! nummy
Originally Posted by ghlkal
(Post 1582880607)
kinda ugly non descript grey
I can't tell if the floor pan has some kind of coating (noise reduction?) or not. Maybe that's just years of grime.
On my gray 1985, the floor pan is gray under the "coating" http://i517.photobucket.com/albums/u...psbc723650.jpg On my red 1990 Z, the floor pan is red under the "coating" http://i517.photobucket.com/albums/u...ps7bc93392.jpg Hmmm ... |
A body shop pal of mine confirmed that my C4 was painted from the center molding downward, which explains the over-spray.
I'm going to remove the rocker panels and cover the over-spray with a little Krylon flat black. Now if I can figure-out how difficult it is to remove the rocker panels.....Hmm
(Post 1582885313)
My floor pan has some kind of thick black tar like gunk sprayed on the bottom. I assume it's supposed to be sound deadener.
(Post 1582947795)
You asked how to and how difficult yesterday or the day before. You've not forgotten already OR have you? |
