E-parking brake ?
How would you take off from an incline when using a stick shift with the E brake .
I never use the e brake. If it's a really steep incline, I usually heel and toe and then let off the brake as the clutch engages.
If you need the e-brake to take off from an incline, you shouldn't be driving stick.
won't that depend on how steep the hill is ?
Originally Posted by Bobbyosto
(Post 1582873371)
Originally Posted by rcallen484
(Post 1582873465)
Unless you are driving some old beater (been there, done that) where you really gotta work the gas pedal while trying to sart it. :rock: :rock: :rock:
Originally Posted by arkus
(Post 1582873353)
:cheers: |
Just release the clutch until you see/hear a slight loss in engine RPM then add more power, release clutch and parking brake, your on the way. Works great or you can add gobs of power, burn clutch and impress your self.
Originally Posted by c54u
(Post 1582873514)
When the e-brake is on, it will hold the car. As soon as you give the car enough gas to go forward, the e-braked disengages automatically.
:cheers: |
what the hell? seriously?
what happens without battery power? it is an EMERGENCY brake after all. what happens if you want to use the handbrake for any number of things? you may WANT to load the car up slightly against the handbrake (test clutch, etc.,). you may WANT to leverage the handbrake while working a car on or off a trailer. a sports car should be able to do a handbrake turn. bottom line, just like everything else, only more so (it is an emergency brake after all) it is vital that the e brake ALWAYS DO EXACTLY WHAT YOU TELL IT TO, ONLY WHAT YOU TELL IT TO, AND NEVER ANYTHING YOU DON'T TELL IT TO. It should not rely on battery power to activate or deactivate. it should not 'turn off' when the car begins to move. surely this is not right? |
is the handbrake even a separate brake anymore? or just software using the caliper and a button? if so, that's even WORSE.
Originally Posted by ramey
(Post 1582873823)
what happens if you want to use the handbrake for any number of things? you may WANT to load the car up slightly against the handbrake (test clutch, etc.,). you may WANT to leverage the handbrake while working a car on or off a trailer. a sports car should be able to do a handbrake turn. bottom line, just like everything else, only more so (it is an emergency brake after all) it is vital that the e brake ALWAYS DO EXACTLY WHAT YOU TELL IT TO is the handbrake even a separate brake anymore? or just software using the caliper and a button? if so, that's even WORSE. jas |
very good questions .
i dont have the answers |
Ramey hates electricity. Here is a photo of his seer 14 home air conditioner.
http://i1090.photobucket.com/albums/...ps2d04dd79.jpg |
(Post 1582873839)
Originally Posted by DREAMERAK
(Post 1582874119)
Do not get in a modern airliner. :lol:
most electric e brakes in new cars still have cable to the brake, servo mtr pulls the cable. I do not believe the corvette has a hyd lock it would be illegal
Originally Posted by al89
(Post 1582874438)
jas |
(Post 1582873823)
what happens without battery power? it is an EMERGENCY brake after all. what happens if you want to use the handbrake for any number of things? you may WANT to load the car up slightly against the handbrake (test clutch, etc.,). you may WANT to leverage the handbrake while working a car on or off a trailer. a sports car should be able to do a handbrake turn. bottom line, just like everything else, only more so (it is an emergency brake after all) it is vital that the e brake ALWAYS DO EXACTLY WHAT YOU TELL IT TO, ONLY WHAT YOU TELL IT TO, AND NEVER ANYTHING YOU DON'T TELL IT TO. It should not rely on battery power to activate or deactivate. it should not 'turn off' when the car begins to move. surely this is not right? This is the EPB brake description from the 13 Malibu. The Vette should be similar: "The vehicle has an Electric Parking Brake (EPB). The switch for the EPB is in the center console. The EPB can always be activated, even if the ignition is off. To prevent draining the battery, avoid repeated cycles of the EPB system when the engine is not running. The system has a parking brake status light and a parking brake warning light. See Electric Parking Brake Light on page 5‑16. There are also three Driver Information Center (DIC) messages. See Brake System Messages on page 5‑27. In case of insufficient electrical power, the EPB cannot be applied or released. Before leaving the vehicle, check the parking brake status light to ensure that the parking brake is applied. EPB Apply The EPB can be applied any time the vehicle is stopped. The EPB is applied by momentarily lifting up on the EPB switch. Once fully applied, the parking brake status light will be on. While the brake is being applied, the status light will flash until full apply is reached. If the light does not come on, or remains flashing, have the vehicle serviced. Do not drive the vehicle if the parking brake status light is flashing. See your dealer. See Electric Parking Brake Light on page 5‑16. If the EPB is applied while the vehicle is in motion, a chime will sound, and a DIC message will be displayed. The vehicle will decelerate as long as the switch is held in the up position. Releasing the EPB switch during deceleration will release the parking brake. If the switch is held in the up position until the vehicle comes to a stop, the EPB will remain applied. If the parking brake status light flashes continuously, the EPB is only partially applied or released, or there is a problem with the EPB. A DIC message will be displayed. If this light flashes continuously, release the EPB, and attempt to apply it again. If this light continues to flash, do not drive the vehicle. See your dealer. If the parking brake warning light is on, the EPB has detected an error in another system and is operating with reduced functionality. To apply the EPB when this light is on, lift up on the EPB switch and hold it in the up position. Full application of the parking brake by the EPB system may take longer than normal when this light is on. Continue to hold the switch until the parking brake status light remains on. If the parking brake warning light is on, see your dealer. If the EPB fails to apply, the rear wheels should be blocked to prevent vehicle movement. EPB Release To release the EPB, place the ignition in the ON/RUN position, apply and hold the brake pedal, and push down momentarily on the EPB switch. If you attempt to release the EPB without the brake pedal applied, a chime will sound, and a DIC message will be displayed. The EPB is released when the parking brake status light is off. If the parking brake warning light is on, the EPB has detected an error in another system and is operating with reduced functionality. To release the EPB when this light is on, push down on the EPB switch and hold it in the down position. EPB release may take longer than normal when this light is on. Continue to hold the switch until the parking brake status light is off. If the light is on, see your dealer. Notice: Driving with the parking brake on can overheat the brake system and cause premature wear or damage to brake system parts. Make sure that the parking brake is fully released and the brake warning light is off before driving. Automatic EPB Release The EPB will automatically release if the vehicle is running, placed into gear, and an attempt is made to drive away. Avoid rapid acceleration when the EPB is applied, to preserve parking brake lining life." Bill |
(Post 1582874653)
Actually it isn't an emergency brake. It is a parking brake.
My CTS-V development buddy suggested I test it when I had my V several years ago. But he warned me to be quick about it, and make sure there was no one else anywhere near me. He was 100% right: the car felt like a 1000-ft giant had stepped on it and squished it into the road. Fortunately I was quick enough to release it before lock-up, so no tires were harmed in that test. jas |
