dba T3 Rotors ZO6 Corvette Front & rear Package Hawk Pads
Corvette Z06 Package 2005-2012 Rotor Slotted Left/Right Front Set http://www.xplosiveperformance.com/t...axx=300&maxy=0http://www.xplosiveperformance.com/t...axx=300&maxy=0 Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Front Package Kit includes (2) Rotors Front Right Front Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package 2005-2012 Rotor Slotted Left/Right Rear Set Rear Package Kit includes (2) Rotors Rear Right Rear Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2441.html $584.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk HP Plus brake pads http://www.xplosiveperformance.com/C...ds_p_2438.html $624.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Rear Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2440.html $541.68 2005-12 Z06 & GS Hawk HP Plus Pads -Front- New 1 piece pads (4/set) 2005-12 Z06 & GS Hawk DTC-70 Race Pads -Front- New 1 piece pads (4/set) |
Can these rotors be used as a direct replacement for the stage 3 rotor on the brembo gt kit on a 2008 z06?
Originally Posted by iwantaz06now
(Post 1582795967)
Originally Posted by Xplosive Performance
(Post 1582797414)
Not sure which GT kit you have by Brembo as they make 3 kits for the front. All the kits have a two piece rotor with an aluminium hat also not sure what your calling a stage 3 rotor Brembo make a Drilled, Slotted, Type III, Type V in 3 different dia 350mm, 365mm, 380mm. In any event the answer is no these will not work and not sure why you would want to put a one piece steel in place of a two piece you're adding a lot of weight. We are a Brembo dealer if you need replacement rings for your kit we can get them for you just need to know which kit you're running
http://execstudio.com/products/bremb...3_gt3rs_01.jpg |
(Post 1582797969)
Sorry I was in a rush and didn't realize the DBA's were a 1-piece steel disk. These are what I'm looking for...I believe they are 380mm:
http://execstudio.com/products/bremb...3_gt3rs_01.jpg Those look like the Type III rotors High Thermal Rotor that Brembo has. We still need to know the size of your current rotor if you have a 365mm and you try to put a 380mm in there wont work and is true the other way. Do you need the hats? Normally you reuse them unless you want spares. The 380mm x 32 type III rotor only is $569.95 ea. |
Hhmmm...my hats look old...how much are those. Its a 380mm rotor
The Hats are $372.60 each.
Corvette Z06 Package 2005-2012 Rotor Slotted Left/Right Front Set http://www.xplosiveperformance.com/t...axx=300&maxy=0http://www.xplosiveperformance.com/t...axx=300&maxy=0 Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures http://www.xplosiveperformance.com/C...et_p_2406.html Front Package Kit includes (2) Rotors Front Right Front Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package 2005-2012 Rotor Slotted Left/Right Rear Set http://www.xplosiveperformance.com/C...t-_p_2407.html Rear Package Kit includes (2) Rotors Rear Right Rear Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2441.html $584.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk HP Plus brake pads http://www.xplosiveperformance.com/C...ds_p_2438.html $624.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Rear Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2440.html $541.68 2005-12 Z06 & GS Hawk HP Plus Pads -Front- New 1 piece pads (4/set) http://www.xplosiveperformance.com/2...t-_p_2433.html $233.00 2005-12 Z06 & GS Hawk DTC-70 Race Pads -Front- New 1 piece pads (4/set) http://www.xplosiveperformance.com/2...t-_p_2565.html $299.99 |
