Originally Posted by NDMIKE88
(Post 1582781512)
Soak the underside of the emblem with WD-40. Let it soak in for several minutes. Work some string (or fishing line) behind the emblem. Once the emblem is removed soak the remaining adhesive with more WD-40 and CAREFULLY remove. Use some polish around the affected area and you are go to go.
Originally Posted by jnguyenn16
(Post 1582781533)
You sir, deserve a pat on the back :cheers:
Nice car! :thumbs:
Hopefully the previous owner just used double sided tape to put that emblem on and you can take it off an have no holes. Just be aware though that on the real Z06, it does have holes in the fenders to mount that emblem. |
(Post 1582781548)
Lets us know how you make out.:thumbs:
:lurk:
It is the case that most people do not not apply badges to try and create the impression that they have an advanced model of the Corvette. To do so would be domestic rice-ish.
(Post 1582781014)
Thanks! Is this common in the Vette community?
(Post 1582781512)
Soak the underside of the emblem with WD-40. Let it soak in for several minutes. Work some string (or fishing line) behind the emblem. Once the emblem is removed soak the remaining adhesive with more WD-40 and CAREFULLY remove. Use some polish around the affected area and you are good to go.
Well???:toetap:
I see there are screens installed on the coves. If you are able to, try to shine a flashlight through the screen to see if there are "studs" poking through the fender behind the badge. If you can't do that, try pulling back the fender liner in the wheel well to see if you can get a look that way.
If the original owner drilled holes in the fender to install those badges, removing them will result in some unsightly holes in the fender. |
It may prove best to leave well enough alone if the former owner modified the fender to Z06 standard – mimicking holes to receive the emblems, with any luck it was on the cheap with the emblem backing ground to a flat finish thereby qualifying for a scar-free reversal. G/L.
http://i702.photobucket.com/albums/w...ps2a8b85e7.jpg |
Congratulations. :thumbs:
Nice looking car. :cool: (but remove the emblems):hide: |
Originally Posted by BearZ06
(Post 1582781043)
Not really, I'd remove them. Great looking car and color! Congrats on the purchase.
I haven't gotten a chance to get around to the emblem, hopefully this weekend
yes,you gotta take the emblems off..its not an acura integra
