Upgrading crank pulley
When installing an A&A kit is it recommended (since it will all be apart)or is the stock one good enough?
They fail even when stock, personally I would recommend it. I went 8 rib on mine that way when it came time to do a 8 rib setup it was already in place. You can still run a 6 rib off of a 8 rib setup (At least with the ECS kit, I would assume A&A is no different but maybe someone can confirm that)
Any recommendations on one?
Originally Posted by revo1059
(Post 1582760478)
I know it all adds up, but may as well do a cam then too if you're swapping the balancer.
Cam was previously done.
So is this what I should look into? http://www.innovatorswest.com/842-LSX-Damper.html |
(Post 1582761452)
Get the 10% over up front, even if you have to pulley up on the blower it is worth it.
You should be able to get one for $500. IW is the way to go. |
(Post 1582762720)
Great, thanks.
Any other special bolts or pins or keys that I might need, or is it just a straight swap? |
(Post 1582762999)
Great, thanks.
Straight swap besides needing to pin it just like the stock one. The stuff A&A sent will work.
I know you can get them cheaper than that though if you look around. |
Great info. Thanks
Can the A&A install be done with the car on jack stands? Also if I do the install myself can the car be driven as is to a tuner or do I have to trailer it? |
Easy on jackstands.
You have a few options on that 2nd part. You could send your ECU for a base tune, find a local to flash in a file for you, tow it, or drive it there with the stock injectors and just swap injectors at the tuner. If you do the last one just don't get on it at all. |
Originally Posted by Unreal
(Post 1582766239)
Easy on jackstands.
You have a few options on that 2nd part. You could send your ECU for a base tune, find a local to flash in a file for you, tow it, or drive it there with the stock injectors and just swap injectors at the tuner. If you do the last one just don't get on it at all |
Crap, the IW balancer sticks out too far for the A&A system (6 rib). I don't want to convert to an 8 rib system (just spending $ I'll never use up to it's potential), so this is what A&A recommends.
http://www.summitracing.com/parts/sum-c2501 |
I would go with ATI. I just ordered one myself.
Does the ATI fit with the 6 rib A&A system? Do you have a part #?
I don't think so. Matt@FPS told me the A&A kit is picky on crank pulleys.
