F/S 2007 Z06 LS7 Longblock or Part out
SOLD!
I dropped a valve like so many others in my 2007 Z06 at about 45k miles. I was going to just repair the head and sleeve but I ended up buying another motor here on the forum. The valve actually dropped when I was in reverse parking the car, so it didn't let loose under load. The #1 cylinder sleeve has a crack in it and the drivers side head has some damage as well as you can see in the pics below. From the research I have done you can have the block repaired/re-sleeved for about $600-$800. The rotating assembly still moves freely so there does not appear to be any other damage. The longblock includes: $2800 - Full rotating Assembly in block - Timing Chain and cover - Harmonic Balancer - Oil Pump - Oil Pan - Custom Made Rear Mounted Dry Sump Oil Tank with steel braided lines - Water Pump - Heads with springs, rockers and push rods - Intake Manifold with fuel rail - 50# Delphi Injectors PM me if you have any questions or email at jad568 at gee mail dot com. Prices do not include shipping... Thanks, -John http://forums.corvetteforum.com/memb...207-131475.jpg http://forums.corvetteforum.com/memb...124-131477.jpg http://forums.corvetteforum.com/memb...637-131554.jpg http://forums.corvetteforum.com/memb...354-131476.jpg http://forums.corvetteforum.com/pict...ctureid=130871 http://forums.corvetteforum.com/pict...ctureid=130870 http://forums.corvetteforum.com/memb...732-131553.jpg |
TTT for a great weekend deal!
what is the bottom dollar would you take for motor heads and intake
Originally Posted by speedyjoe
(Post 1582739813)
Monday Bump... Engine is coming out tomorrow and will be ready to go!
Engine is out and ready for a new home!
http://forums.corvetteforum.com/memb...207-131475.jpg http://forums.corvetteforum.com/memb...354-131476.jpg http://forums.corvetteforum.com/memb...124-131477.jpg |
Friday bump! I'm now throwing in the dry sump custom made tank and lines as part of the longblock deal!
Weekend bump....
PM sent
pm sent
not a bad deal. good luck!
Originally Posted by walhan_qtr
(Post 1582813318)
I have no reply
Originally Posted by Jasperstang308
(Post 1582814460)
I have no reply
Good evening
I PM'ed you.
Ttt
ttt
ttt
Priced Dropped from $3000, now $2800 takes the entire longblock with all components mentioned.
-John |
ttt - Weekend Deal!
