LS2 ENGINE 3500miles *Need 1 piston* 2500$
LS2 engine
2006 (24x) 3500 miles Need a piston and exhaust valve on cyl#5 Comes with accesories,intake. No injectors and damper but i can add 60LB inj and ATI damper for more. 2500$+shipping. bovi_z@hotmail.com or pm for infos. |
Saw your other post about SC kit you selling, seems like i assumed you lost #5 cyl because of SC'ing, just install one piston and valve can be replaced with mininaml expenses.
If #5 cyl walls are good than just buy one piston and call it a day. Such a low mileage n your motor its sad, i lost 3 pistons on my stock LS6 block and installed 3 pistons call it a day. GL whatever you decide, its a inexpensive rebuilt i say rebuilt and enjoy, let me know if i can be your help. |
Labor is expensive in here. Engine broke due to detonation. Iat sensor broke and i had to much timing
I did myself only cost was pistons rings and gasket sets....less than $500. Let me know if you decided to do the way i did, engine does not has to come, i can drop cradle, drop oil pan, remove cyl heads, install one piston and put everything back together....you good to go....still lots of labor but can be done.
I understand your loss, and pain if somebody's is doing labor. I feel your pain..GL on sale. What ATI dampner you have? do you part number...i might be interested in that in case if you sell separately. |
I'll not sell separately. Thanks mate but as im working 7/7 so i'll let somebody rebuilt it and enjoy the engine i guess.
2500$ lets go
