Simple Build-Big Power-LSA style!
Going to do a new build for 2013 at DasilvaMotorsports. Basically to get the most out of the least-but by no means are we cheaping out-but were going to put the money where we feel is going to give the best return.
And with all that we have learned over the years-we have a pretty good understanding what we need and what we don't need. Here's what we have collected: http://i127.photobucket.com/albums/p...2-26133532.jpg A brand new LS2 aluminum block, some Wiseco pistons with the older 1.5/1.5/3mm ring pack ( thanks to Rob@Champion for a killer deal on these parts!), a set a LSA heads which will get sent out for some CNC porting. Were just waiting on a set of K1 billet H-beams and a 4340 stock stroke crank. This is going to be a 365 cube motor topped with a YSi-goal is too make 1000 rwhp plus and run 8.6-8.8's at 160+mph. We also have plans to run this combo at a 1/2 mile event in Chicago this June, our goal is to run 185-190 mph in the half mile. After this combo is thoroughly tested and put through it's paces-it will get yanked, refreshed and sold to a lucky customer-a tried/tested and proven combo! |
Originally Posted by Arun@Dasilvamotorsports
(Post 1582660930)
And with all that we have learned over the years-we have a pretty good understanding what we need and what we don't need. Here's what we have collected: http://i127.photobucket.com/albums/p...2-26133532.jpg A brand new LS2 aluminum block, some Wiseco pistons with the older 1.5/1.5/3mm ring pack ( thanks to Rob@Champion for a killer deal on these parts!), a set a LSA heads which will get sent out for some CNC porting. Were just waiting on a set of K1 billet H-beams and a 4340 stock stroke crank. This is going to be a 365 cube motor topped with a YSi-goal is too make 1000 rwhp plus and run 8.6-8.8's at 160+mph. We also have plans to run this combo at a 1/2 mile event in Chicago this June, our goal is to run 185-190 mph in the half mile. After this combo is thoroughly tested and put through it's paces-it will get yanked, refreshed and sold to a lucky customer-a tried/tested and proven combo! And as I mentioned, I have a 4340 Forged Stock stroke crank for sale... :D |
Go Arun Go!!! :cool:
ttt
Sounds like a winner to me buddy, cant wait to see the JAM it will be making on the rollers.:thumbs::thumbs: Robert
Nice package, are you using your new cam in this package? What CR are you going with on this motor?
Looking forward to seeing it run the 1/2 mile in June!:thumbs: |
Outstanding, cool great move.
Originally Posted by Blitzkrieg
(Post 1582661395)
Can't wait to see the build progress and the results. :canadaflag:
:lurk:
good luck on the build Baezi |
(Post 1582661395)
Looking forward to seeing it run the 1/2 mile in June!:thumbs: LS2 block will get the mains pinned and we'll upgrading the piston pins to heavy wall tool steel. Not messing around with a stock crank/relucter so this is getting a double key-wayed K1, so it should be fine for 7500 rpm shifts. Cam is going to be something mild to take advantage of the big port LSA head. :cheers: |
This sounds very familiar to someone else's LS2 I know well. :lol::cheers:
Originally Posted by DOUG @ ECS
(Post 1582661960)
I spent the whole weekend looking at some of the fastest blower cars-with the smaller blowers. What I found commom was the short stroke, 3" to 3.4". There is something to be said about that. :cheers: |
(Post 1582662040)
Yup-I think I know that car. IMHO that car can go alot faster-and i'm sure he will.
I spent the whole weekend looking at some of the fastest blower cars-with the smaller blowers. What I found commom was the short stroke, 3" to 3.4". There is something to be said about that. :cheers: Yup, I cant say we "knew" what we were doing when that was assembled, it just happened, but I rarely see a bigger cube or a bigger $$ build compete with it. (at our level) I think that car has 8.0's in it, we'll see once it all comes together next season. Stroker motors dont seem to make any difference really either from my experience on track, street ok, but not on track. I also haven't seen the difference with huge cams either, but I'm putting a monster cam in my build this year so I'll see how that works out. |
what would that motor cost to build minus the blower? I mean ready to be installed I would use my blower.
That is a good lookin build, 185 - 190 in the 1/2 mile is very fast, how long is the brake zone in chicago ? Maybe it`s time for a brake upgrade also, eh buddy ? :crazy2:
Originally Posted by LedfootLarry
(Post 1582662775)
Stopping won't be a problem-like the Canadian event-that's why Frank and I are passing on that event. Plus my new setup includes a Parachute out back. :D http://i127.photobucket.com/albums/p...-53-02_575.jpg |
Buddy can't wait to see the results:rock:
Originally Posted by Dave concrete
(Post 1582662637)
This build includes Torque plate honing of the cylinders Line hone mains after doweling and pinning main caps Square deck block surfaces 90* from main tunnel Dowel pin main caps Balancing Hellfire rings Speed Pro main Speed Pro rod Speed Pro HD babbit cam bearings Wash, file fit rings, set all oil clearances, final assembly With all the parts, new LS2 block, K1 billet rods, K1 4340 crank, Wiseco pistons, ARP main and head studs. Total ends up an easy $5500. There are alot cheaper alternatives out there but the fellow I deal with builds one engine at a time in a state of the art facility. I only give out his name to a close friends-so he has time for my builds. Don't forget-to add to this we still need a new LS2 front cover, valley cover, the kock sensor and cam harness, oil pump, timing chain, camshaft and lifters. That's why when I sold my last engine combo from top to bottom for 10k-it was a STEAL!!!!!! That's why it sold so quick-there's gonna be one fast, fast car in Finland! :cheers: |
Shoot , he`s got a chute :rofl:
Glad you and Frank are not going to the Ottawa event, the runoff is short, and now Ian and I don`t have to worry about you clowns :D |
(Post 1582663199)
Glad you and Frank are not going to the Ottawa event, the runoff is short, and now Ian and I don`t have to worry about you clowns :D :cheers: |
