Looks almost exactly like the original Jalopnik rendering. The splitter is about the only difference.
It appears crow will, indeed, be eaten by some. |
Originally Posted by Scissors
(Post 1582592561)
Nothing new here, but solid confirmation from GM that the leaks were indeed the car.
(Post 1582592561)
Originally Posted by 1320vetteran
(Post 1582592598)
It doesn't to me. On this illustration the vents are lower, the lights are bigger and there is a more of a "curve" in the hood.
(Post 1582592598)
Subtle details here in this service man. sketch that make it even better! :rock: |
Originally Posted by Process Black
(Post 1582592325)
The side gill/gash-thing is too gaudy... What purpose does it serve? I hope it looks better when the rest of the car is visible.
Don't we see a front license plate holder right in the middle of that "grille"? Hopefully it can be removed seamlessly if unnecessary.
Originally Posted by rcallen484
(Post 1582592815)
Sonny |
Hmmm, this view hints that the hood vent may be on all of the models.
I wish they had an illustration of the air diverter up through the engine compartment and to the hood vent. |
Originally Posted by CandyRed77
(Post 1582592884)
A year and a half ago I talked to Tadge Juechter about the lack of a decent place to mount a front plate on a C6 and he mentioned they came up with a good sollution for the C7 that would both look good and still allow for the huge air intake opening they wanted for the race cars (they didn't want the split opening as the C5 has). I think what we are looking at in this drawing is a removable part mounted in the opening. So if you need it for a plate, leave it in, otherwise, take it out :thumbs:
Sonny |
(Post 1582592884)
Sonny |
(Post 1582592598)
This drawing seems to show the crease that runs along the top of the fenders, along the inside edge of the headlights, and then to the leading edge of the nose. None of the renders got that as well as I thought they should according to the Omega leak.
Also, I like the nose having a bit of an "overbite" where the top of the nose is looks to hang out a bit over the bottom... ala C3. -D |
Lot of small differences from the "renderings" that gives it a much better appearance. Looks similar but isn't. BTW, that's an air dam/deflector(C6 ZR1 also had them) shown in the illustration that is bolted to the lower A-Arm, not a splitter that is bolted under the chin.
Originally Posted by Gobot
(Post 1582592331)
Cool. Looks like a Ferrari 599gto
(Post 1582592561)
Do the rotors appear to be two piece units to anyone else? Looks like that disc bolts up to the hat to me.
Originally Posted by Nitrous Oxide
(Post 1582593060)
They will say that a crease here and there is off by half an inch, and therefore Jalopnik was total fiction.
