FS: aeromotive eliminator pump...external
Part Number: 11104
Eliminator Fuel Pump, P/N 11104 For high horsepower Strip/Street applications, EFI or carbureted. For fuel injected engines: Up to 1600 HP - naturally aspirated Up to 1100 HP - forced air induction For carbureted engines: Up to 1800 HP - naturally aspirated Up to 1500 HP - forced air induction Designed for forced air induction machines running on the street and at the track. The Eliminator gives you about 25% more flow at pressure compared to the A1000. Proprietary aerospace composite technology is built into the patent-pending "dual chamber" pumping mechanism. Pump flow exceeds 800 lbs. per hour @ 13.5 Volts and 45 PSI. Pump flow exceeds 1,000 lbs. per hour @ 13.5 Volts and 8 PSI. Inlet port is -12 AN O-ring boss, outlet port is -10 AN O-ring boss. For EFI engines use regulator P/N 13110, carbureted P/N 13202. Fully submersible for custom, in-tank placement. The continuous duty, "street warrior", supports more HP in a true street car than any other pump built. Billet Pump Controller (P/N 16302) recommended to keep fuel cool on long trips. Used for about 1000k miles, going in a different direction. $300....PRICE DROP http://ls1tech.com/forums/attachment...g-imag0704.jpg |
