Dreaded Pull Key Wait 10 Seconds
Just completed installing the LCM 5 from Compliance, C5 MM6 would not run over 1 mph, Service Steering Column & Pull Key Wait 10 Seconds in a real fix. Called Richard and he sent his LCM 5 and I installed with great results so far, everything works again, why Compliance and not GM?:willy:
I'm having key issues. What was your reason for needing this?
changed low battery after change the service steering column, pull key wait 10 seconds came up on the dash and car would shut off if i got over 1 mph, has origin from the steering lock that had a recall from gm
Originally Posted by canada9
(Post 1582543528)
Glad you got yours fixed. |
