FS: ProCharger D-1SC kit
I changed my setup, so I have the following parts for sale:
1. ProCharger D-1SC head unit with the polished finish and helical gear upgrades. Also includes a 4.75" 6-rib pulley and the 6-rib belt to drive everything. Since I'm local to ProCharger I dropped the head unit off for an inspection to give buyers peace of mind. If any repairs are needed, they will be done under warranty, so the head unit will be like new. 2. ProCharger 6-rib bracket system (engine bracket, blower bracket, tensioner, standoff's, ect.) 3. ProCharger intake and air filter 4. Procharger 'intercooler cover plate', or whatever you would call the black plate that covers the radiator/ac condensor and intercooler. (cut to allow larger air filter I was running, will provide pics with more detail) 5. FAST 65lb injectors that came with the kit. 6. KB Boost-a-pump with racetronix wiring harness Basically the only parts you will need are some intercooler pipe, the intercooler and a bypass valve. $2,950 + shipping. I'm located in Kansas City and am also willing to drive a reasonable distance to meet buyers. My inbox fills up sometimes, so please email me at turbotuner20v@aol.com Here's a picture of the setup on the car, I'll have more pictures of the parts off the car when the head unit comes back from ProCharger. https://sphotos-a.xx.fbcdn.net/hphot..._3047937_n.jpg |
Here's what you would need to complete the kit:
harmonic balancer pin kit lowering cradle for radiator w/ air dam intercooler mounting brackets 1.25" tube to extend radiator hose oil cooler bracket misc. coolant hose power steering cooler vacuum manifold misc. pcv hose Here are the parts for the intercooler setup (ignore the oil cooler brackets/spacers and factory oil cooler, those are listed above) http://img96.imageshack.us/img96/907...cschematic.jpg I can also include a full instruction manual to assist with the installation. |
I forgot, I have a KB boost-a-pump and a Racetronix wire harness too
Great Price
what a great price free bump for you
Thanks guys, looking to move this fairly quickly and with limited haggling. I dropped the price a few hundred already and threw in the KB BAP and harness and it's only been listed a few hours :willy: :D
Shoot me a pm if you decide to spilt. I would be interested in the injectors and boost a pump if you do. Thanks
Originally Posted by 2002BLKTA
(Post 1582543343)
Sounds good thanks man
too bad not for an ls2, im looking for one right now
It will work on LS2/LS3 same kits. Only difference is injectors.
Originally Posted by slowlsx2005
(Post 1582543524)
Originally Posted by mourat
(Post 1582543545)
I know for sure that ProCharger support confirmed that the LS3 and LS7 kit are interchangeable, but if it's just the injectors (like mentioned above) that make them different than the LS2, I can sell those seperately if someone doesn't need them. |
let me check with them, if it works i'll see what the rest will cost
They said only the head unit and a few small pieces matched up when called them.
God damnit if it was only tax return time
How many miles on the kit?
Bump for you. I wonder whats to come???
Originally Posted by Fly'n Family
(Post 1582546352)
Originally Posted by Detoxx03
(Post 1582546773)
bump
