installing aftermarket alarm
Hey guys, just wondering if anyone on here has ever put an aftermarket alarm(with remote door locks) onto their c4, in particular an 84. Is this something I can do or should I be bringing this to a shop? thanks for any help!
You don;t have the VATS so its not a huge deal..DO make sure whatever you buy, will be compatable with the GM system..if you have one. I forget what exactly was installed in 84...VATS did not come around until 86 IIRC..
I've seen keyless entry, remote start, all the toys. |
I have done a couple of car alarms way back when, never on a Corvette though. They can be a PITA to install, and if something goes wrong the alarm "engine cut off" down the road. If you have patience, a wire diagram, and take your time you can do the install yourself and you'll end with a MUCH better install than any of the shoddy work I've seen from Alarm/Stereo shops. There are A LOT of wires in a C4, and the interior trim pieces are old (brittle) so great care must be taken.
Ask yourself: do you really need an alarm system? Then ask: do I really want somebody working on my Vette? |
Originally Posted by DanZ51
(Post 1582453120)
Here is the theft deterrent for the 84..
http://i270.photobucket.com/albums/j...ftdeterent.jpg http://i270.photobucket.com/albums/j...or/84theft.jpg :cheers: |
Originally Posted by ccrazor
(Post 1582453671)
:cheers: |
factory good, i use the horn on my aftermarket, no siren so an intrusion sounds the same. I had a shop install it years ago and the brittle plastic broke everywhere< i got over the pain, it didn't help those aholes didn't give a $hit.
VAT can be problematic, buy a defeat bypass or reburn the prom chip aftermarket will give you keyless entry and hatch release, engine off door unlocking, flashing light ( this is a good one) and shock sensor and of course the siren if you prefer. as far a piece of mind, the stock one will do the trick, but the aforementioned features will modernize the old vette I use a club the flashing light I broke dicking with the interior work one day. |
You have a factory alarm system, I don't think 84 had an anti-theft system though.
