Originally Posted by Abnmarine
(Post 1582466136)
Same issues for me. Would my tires cause this?
275/30/19 rear 235/35/18 front Not trying to hi jack. A lot of good info here. HOWEVER, it looks like last owner did a poor job picking appropriate sized tires. |
Just for future reference for anyone that needs it, here's the diameter calculator that I used the other day:
http://robrobinette.com/tire_diameter.htm |
Originally Posted by ajchance
(Post 1582466935)
http://robrobinette.com/tire_diameter.htm http://www.rimsntires.com/specs.jsp Toque |
Originally Posted by Toque
(Post 1582466805)
Not sure who chose your tire sizes but They are interesting to say the least. :D. Your rear is 1.2" larger than your front so you should be fine with Active handling/TC. Your speedo is going to be off though.
Front 235/35/18 - 24.4" Rear 275/30/19 - 25.6" Rear is 1.2" larger Stock C5 diameters: Front 25.7" Rear 26.7" Stock Z06 diameters Front 25.4" Rear 26.1"
Originally Posted by dblerman
(Post 1582466830)
That combination works in relation to having the correct diameter stagger.....
(Post 1582468592)
Appreciate the replies. What would be the correct size if I replaced them? Is staying with the stock diameter best?
I run 275 front on 18x9.5 and 285 rear on 19x10. |
(Post 1582468592)
I would assume that you went with a 9.5 or 10" front, and a 10.5 or 11" rear. In that case most go with 265/35/18 front - 25.3" 305/30/19 rear - 26.3" Rear is 1.0" larger than front :thumbs: 275/35/18 front - 25.6" 305/30/19 rear - 26.3" Rear is 0.7" larger than front :thumbs: Toque |
(Post 1582469241)
What are your rim widths ?
I would assume that you went with a 9.5 or 10" front, and a 10.5 or 11" rear. In that case most go with 265/35/18 front - 25.3" 305/30/19 rear - 26.3" Rear is 1.0" larger than front :thumbs: 275/35/18 front - 25.6" 305/30/19 rear - 26.3" Rear is 0.7" larger than front :thumbs: Toque 275/35/18 front - 25.6" 305/30/19 rear - 26.3" I will measure my wheels to see how wide they are. |
(Post 1582470488)
I like the
(Post 1582470593)
Should be stamped on the back of your rims. If you only have 10" rims in the rear, you're not going to want 305s.
I'm looking at the Hankook V12 tires
275/35ZR18 that are 25.6" tall for the front 285/35ZR19 that are 26.9" tall for the rear Is this a good choice? Both will fit my rims. |
(Post 1582472777)
I've searched and can't see the stamped size. I haven't removed the wheel thought to check. I did measure the width and it looks like they are 10.5" wheels.
You will need to take the rim off and look at the measurement stamped on the back. |
(Post 1582473035)
Not sure how you measured the rim with a tire mounted on it :confused2:
You will need to take the rim off and look at the measurement stamped on the back. http://www.northerntool.com/images/p...ges/135472.jpg |
(Post 1582473459)
I'd still take the rim off and double check though |
