'99 FRC, (TONS of new parts)(scroll down for pics)
1999 Chevrolet Corvette "Hardtop", 6 speed, torch red with black interior. Odometer reads 88K miles but most parts are new. This car was a great project, now that it's complete, I'm selling it to start another... The result is one extremely nice example of this legendary model, the hardtop. All items listed below have been installed new this year, (approx 800 miles). The engine had a spun rod bearing and has been completely rebuilt by a well known DFW LS1 engine builder. After the proper break in, the engine runs perfect with tons of power.
New parts: (approx 800 miles since install, new) (I have all the receipts for parts listed) Corsa Xtreme catback Clevite main bearins Clevite rod bearings LS7 lifters GM lifter trays Total Seal piston rings GM rear cover GM timing chain Fel Pro front cover gasket Fel Pro intake gasket Bypass gasket GM head gaskets Fel Pro head bolts GM pistons, rods (Oil and filter changed after initial start up and at 500 miles, conventional Valvoline 10w30) GM power steering pump pulley GM Rear main seal GM manifold gaskets GM crankshaft pulley bolt. Serpinetine belts TR6 spark plugs Fuel filter Complete GM pcv assembly A/C service and charge GM water pump GM thermostat and housing LS6 slave cylinder LS6 clutch kit GM air filter GM ceramic brake pads (front/rear) GM power steering reservior ZIP lowering bolts front and rear Fluids: (replaced 800 miles ago) DexCool coolant GM brake fluid, clutch hydraulics all new Valvoline 10w30, AC Delco oil filter A/C freon GM power steering fluid Amsoil transmission fluid Interior: (new) Re-upholstered headliner Re-upholtered seats, center console, door panels, sun visors. Lloyds floor mats. Rear partitian Ipod2Car kit Machine work: Cylinder heads complete valve job Crankshaft Non new parts: Bear Brakes Eradispeed rotors front and rear. ZO6 replica wheels (black-no rivets), 18x 9 front, 18x 10.5 rear (the car does need a front wheel bearing) This car is totally reliable as it should be and is an absolute joy to drive. I'm ready to start another project so this one must go. $18,500 clean texas title in hand Alex 817-716-7912 http://i177.photobucket.com/albums/w...s/IMG_0512.jpg http://i177.photobucket.com/albums/w...s/IMG_0513.jpg http://i177.photobucket.com/albums/w...s/IMG_0514.jpg http://i177.photobucket.com/albums/w...s/IMG_0516.jpg http://i177.photobucket.com/albums/w...s/IMG_0517.jpg http://i177.photobucket.com/albums/w...s/IMG_0518.jpg http://i177.photobucket.com/albums/w...s/IMG_0519.jpg http://i177.photobucket.com/albums/w...s/IMG_0520.jpg http://i177.photobucket.com/albums/w...s/IMG_0521.jpg http://i177.photobucket.com/albums/w...s/IMG_0522.jpg http://i177.photobucket.com/albums/w...s/IMG_0523.jpg http://i177.photobucket.com/albums/w...s/IMG_0524.jpg http://i177.photobucket.com/albums/w...s/IMG_0525.jpg http://i177.photobucket.com/albums/w...s/IMG_0526.jpg http://i177.photobucket.com/albums/w...s/IMG_0527.jpg http://i177.photobucket.com/albums/w...s/IMG_0528.jpg |
