What pressure should I use on my BFG 315 drag radials??
I have a brand new pair of 315's on 17/11 rims.. What tire pressure would you suggest???
Re: What pressure should I use on my BFG 315 drag radials?? (Cha Cha)
Start at 24 lbs and see how they work.
Re: What pressure should I use on my BFG 315 drag radials?? (mackeyred96)
I just tried out my new set of 315 35 17 drag radials last week at the track in Memphis. I couldnt hook with 20lbs. My best 60ft was 2.18. Any suggestions??????
BG |
Re: What pressure should I use on my BFG 315 drag radials?? (Bgreenard)
I have had good success at 21 PSI on mine.
Be sure you get a fair burnout on them to make them sticky. |
Re: What pressure should I use on my BFG 315 drag radials?? (REDGAR)
Thanks, I need to work on doing a better burnout, Im being told I need to go until I see some white smoke.
BG |
Oh yes, white smoke is a must.
Take a look at these pics of my car the red c5 with 6467 on the glass at http://www.corvettechallenge.info/2002/event5 |
