Wipers and Washers not working
My 1996 C4 is giving me problems, yet again!!
I purchased the car recently, the Wipers and Washers were working until yesterday....I turned the switch on the stalk, nothing. I tried to activate the Washers, nothing. The fuses are all fine....and I'm stumped. Any ideas please.... Thank you:crazy: |
The 'cover' of the wiper motor has PC board in it. Unless your problem is at the steering column end, I would bet that the problem is in the motor cover. They are $$ to replace, so you want to follow the wiper/washer switch test in the FSM, using a multi-meter. If you don't have a 1996 FSM, maybe someone can scan that for you.
