I have an LED that is adjusted to stop me exactly on the spot. Cheap and easy to install. :thumbs:
I'm thinking a high tech ping pong ball on a string. Color it the same color as your car :D
Mark 1 eyeball. :thumbs:
I stop when my passenger mirror gets to the orange-handled garden fork on the right hand wall. Hope that helps!
I use a 2" X 10" X 6' wooden board on the garage floor for a stop.
I use the "0" on the HUD as a sight.
I line up the bottom of the 0 with the top edge of a white box (with old wheels inside) that is next to the skinny MG I'm parking behind. I end up with 4" clearance in the front and about 6" for the door to come down behind. You could park your car where you need it and have someone draw a line on the wall that lines up with the HUD's display. |
Rubber parking block I got on ebay
glue a 2X4 about 30" long to the garage floor at the frt tire...............right where i need the car to be....:):)
Honestly, the ingenious apparatus I use is my brain, it has yet to fail me.......and it is free. :lol:
I use a 2"x6" piece of wood I have painted bright red and then put white stripes* on. It is glued to the floor and when I feel it I stop. I also use a weighted piece of string hanging from the ceiling with a weight on it to guide me in horizontally.
*Red with white stripes is to keep stupid people like me from tripping over it when the car is not in the garage. |
I use a very simple method and since I change cars often it makes sense for me.
I park the car where I want it in the garage and open the door.I put a piece of masking tape on the floor (or a sharpie mark) in line with something on the door sill of the car. Everytime I pull in I just crack open the door open and pull up so the tape aligns with my chosen spot on the sill and it is perfect everytime. No silly balls hanging from the ceiling that shows everyone you can't park your own car.:D |
Originally Posted by mcandrew67
(Post 1582285768)
I use a sensor stoplight
http://www.ebay.com/itm/New-Park-Zon...item4abe219c45 |
I use a piece of 2x4 about 18" long for the right front tire. My is now anchored, but I have a line drawn to indicate were it goes.
Originally Posted by davidtcpa
(Post 1582288590)
I wish I knew about this. I use the tennis ball on my garage door release string.
:thumbs: |
Tennis ball idea with a small white plastic nut. I'm just as concerned by right and left since I tend to pack the garage. Drive straight toward the nut and stop when it touches the mirror mount on the windshield. This gives me a very tight grouping of tire marks on the floor.
I have some utility carpet squares piled up on the floor of the garage and stop when I roll up onto the edge of the pile.
Originally Posted by C6RaceCar
(Post 1582288133)
http://www.autosportcatalog.com/park...FcxcMgodwTkAUA
http://www.autosportcatalog.com/imag...g_signal_1.jpg |
Park your car exactly where you want it in the garage, then sitting in the seat normally, turn your head to the left and look for a object on the wall and just look for that same object everytime you are parking. I have a 2X4 stud on my wall that dish network installed their splitters on and when I am looking at that, I know my car is parked exactly where I want it. Free!!
