A C7 hypothetical...
OK, I'm not much of a techie so I am asking a technical question to those who are knowledgeable about engines/performance issues. I'm NOT asking if you want to see AWD or your opinion of AWD.
So, let's assume that the LT1 engine we have seen would indeed get from 0-60 in under 4 seconds with the base C7. Lets also assume that base C7 is right at 3000 lbs. NOW, lets assume you added an AWD system that is similar to the Ferrari FF that adds approx. 120 lbs to that car. http://blog.caranddriver.com/funky-f...-drive-system/ Now, given this scenario, what might the 0-60 number be with this new C7? The quarter mile? BTW, the FF gets to 60 in 3.5 seconds and is about a two ton car with 650 hp and less than 400 ft lb of torque. Please...no arguments just an interesting discussion of potential. Can you tell I'm bored waiting for the 15th?? |
Does anything under four seconds matter? I don't think so. I think once you get down to four seconds 0-60 you should take that measurement off the table and move to something like 0-100 or quarter-mile. The amount of variation in conditions and drivers makes sub-four-second 0-60 times distinctions in search of differences.
I think the AWD edition would be a skosh quicker in the quarter mile, assuming stock "Z51" street tires at touring conditions. Could purpose-built 1/4mi tires make the 2wd C7 just as quick as an optimally-tired AWD edition, given the still-modest power? I don't see how that question can be answered without descending right back into the depths of "is or is not AWD superior to RWD off the line" hell with its Guibo and 911 references... but I wish y'all luck. |
Originally Posted by Jinx
(Post 1582285691)
I think the AWD edition would be a skosh quicker in the quarter mile, assuming stock "Z51" street tires at touring conditions. Could purpose-built 1/4mi tires make the 2wd C7 just as quick as an optimally-tired AWD edition, given the still-modest power? I don't see how that question can be answered without descending right back into the depths of "is or is not AWD superior to RWD off the line" hell with its Guibo and 911 references... but I wish y'all luck. Trust me, I'm the last guy who really cares about 0-60 in my day-to-day Corvette existence. :) |
Originally Posted by BlueOx
(Post 1582285564)
So, let's assume that the LT1 engine we have seen would indeed get from 0-60 in under 4 seconds with the base C7. Lets also assume that base C7 is right at 3000 lbs. NOW, lets assume you added an AWD system that is similar to the Ferrari FF that adds approx. 120 lbs to that car. http://blog.caranddriver.com/funky-f...-drive-system/ Now, given this scenario, what might the 0-60 number be with this new C7? The quarter mile? BTW, the FF gets to 60 in 3.5 seconds and is about a two ton car with 650 hp and less than 400 ft lb of torque. Please...no arguments just an interesting discussion of potential. Can you tell I'm bored waiting for the 15th?? Maybe the weight balance shift in the C7 will dramatically change things.. |
Well, the FF does 0-60 in 3.5 and the F12 does it in 3.1. The F12 is apparently not so traction-limited that it can't ace its AWD brother. You could point out that it's not a fair comparison, not apples-to-apples enough, but that's the fundamental dilemma of this hypothetical -- not enough apples. The same old 911 traction discussion is inevitable.
FF - 4,150 lb - 651 HP V12 - 0-60 in 3.5
F12 - 3,362 lb - 730 HP V-12 - 0-60 in 3.1 I'd love to see a stripped down (to 3,400 lbs) FF take on a F12..just for fun. |
OK, now if anyone who really is a techie has an idea about this, I'd love to hear from you.
I think your best comparison would be an older GTR with a claimed 470 HP and a C6Z06. With the GTR weighing over 500 pounds more but the HP being underrated, they run almost the same ET. Just remember if the cars aren't driven by a driver with drag race experience, "Your results may vary" http://www.roadandtrack.com/content/...Turbo_data.pdf
Mike V |
How much will this theoretical RWD C7 be traction-limited off the line, and how much will the Ferrari FF type AWD system improve matters? How many ticks off the quarter-mile time?
(Post 1582290324)
(Post 1582290394)
I don't know. How much does the 750+ pound advantage and almost 100 more HP of the F12 only buy it a .4 second advantage in 0-60 over the FF?
(Post 1582290394)
Also, "only .4" -- see my first msg about the limited value of 0-60 comparisons below four seconds. Or look at "only .4" another way and recognize that the F12 is over 11% faster to 60 than the FF.
(Post 1582290470)
But it still buys an advantage. Come on, it's your topic, stick your own neck out. How many ticks do you see your hypothetical AWD C7 taking off the quarter-mile time?
Oh, I see. "Only post if you have the kind of answer I'm wishing for." You know that's not the way this forum has ever worked. We're all bored waiting for the 13th.
Does the AWD version need to be any faster to make you happy? I thought it was the four-seasoning of the FF that tickled your fancy. |
Blue Ox,
This is yet another response to your OP that doesn't provide the simple number estimate thst you are seeking. Sorry, but, IMHO, your OP is in fact a classic example of a simple question that doesn't have a simple answer. So please indulge me a non-simple non-answer. My experience dabbling in drag racing decades ago has left me highly skeptical of the accuracy of published 0-60 times of less than about 5 seconds for any car. That's because, for cars this fast, seemingly little details affecting traction can affect the 0-60 time by at least +/- 1 second. What kind of tires and tire pre-conditioning? More importantly, what kind of track surface -- a dusty seldom-used back road or a VHT-preped drag strip at an ideal tempeasture or something in between? Consider this article about a "stock" Ford Mustang (factory-produced rear-wheel drive drag race Mustang with supercharged 5.4-L and AT) that does 0-60 in 1.52 seconds: http://www.dragracingonline.com/feat...-butner-1.html As stated in the article, the all-wheel drive Bugatti Verron supposedly does 0-60 in 2.57 seconds. My intuitive answer to your OP question is something like: On a typical city street, a hypothetical AWD C7 with an extra 120 pounds would probably be at least 0.5 seconds faster 0-60. On an ideally prepared drag strip and if the RWD C7 had ideal tires, my guess is that the AWD C7 would still be faster 0-60, but perhaps by as little as 0.1 or 0.2 seconds. |
Originally Posted by 235265283...
(Post 1582291354)
I think in short distance, straight line (like a 0-60), same power, same tires, same surface, same driver capability, same hp/torque, same gearing, 120lb penalty for the AWD. . .
that the AWD platform would be .2 - .3 quicker. Whether that would hold thru the 1/4 (and farther) or whether it would be a benefit/penalty on road course would get even deeper into the weeds into gearing and hp/torque per pound for the former (i.e. whether one can stay in the sweet spot of the torque curve to overtake that extra 120 lbs in the 1/4) and into the weeds on chassis characteristics for the latter. Just a guess based on gut and experience. Would be fun to model it. |
Ox, I am thinking in the 3-3.25 range for 0-60 in AWD form. The 60ft time would be dependant on launch rpm and driver skill but I bet it would trap high and still be a very low 10 second car. Thanks for causing me to speculate and dream about this now. LOL
what about the C7 second year imaginary add of VWD( variable wheel drive), which allows the LFS(launch faster system) to utilize all four wheels to get going, monitors rear wheel spin, and shifts to rear wheels only in 27 milliseconds on cue? allegedly cuts 86/100ths of a second off 0-75 times in my dreams.
(Post 1582286005)
0-60 is not everything but thats the first thing most people look for when they read a article on a car... 0-60 and 1/4 mile times.
This isnt Germany and we cant run foot to the floor on the freeway so most people dont look at top speed. I dont understand why the traction issue with the newer Vettes. Yes they have more power but allot has been done over the years to help with traction. Example: Unlike my old C4 the newer vettes have traction control, Launch control, the transmission is in the back and all kinds of electronic aids. Since it looks like Cadillac helped design The C7 (only going by what ive seen) why didnt they help implement one of there AWD systems into the C7 for those who want AWD A on demand AWD system would put the Vette in a new league. Hows this for a C7 opening commercial. Its a snowy day and out from the white cloud of snow you see 2 headlights. As the lights get closer you here the sound of the new LT1 engine. Then the new C7 swooshes by. Then the words "C7 AWD, THINGS HAVE CHANGED" appear on the screen. That will blow peoples minds :D |
Originally Posted by rad928music
(Post 1582292701)
Since it looks like Cadillac helped design The C7 (only going by what ive seen) why didnt thay help implement one of there AWD systems into the C7 for those who what AWD. A on demand AWD system would put the Vette in a new league. Hows this for a C7 opening commercial. Its a snowy day and out from the white cloud of snow you see 2 headlights. As the lights get closer you here the sound of the new LT1 engine. Then the new C7 swooshes by. Then the words "ATS AWD THINGS HAVE CHANGED" appear on the screen. That will blow peoples minds :D :cool:idea! You should copyright that and sell it to Cadillac to use on their AWD models! :cheers: |
Originally Posted by tuxnharley
(Post 1582292532)
Hmm - well, since this is a hypothetical discussion, how are ya gonna get 750 pounds:eek: outa that FF - without also including losing the 120 lbs of the AWD.................:D
(Post 1582292701)
Unfortunatly this isnt Germany and we cant run foot to the floor on the freeway so most people dont look at top speed. I dont understand why the traction issue with the newer Vettes. Yes they have more power but allot has been done over the years to help with traction. Example: Unlike my old C4 the newer vettes have traction control, Launch control, the transmission is in tha back and all kinds of electronic aids. Since it looks like Cadillac helped design The C7 (only going by what ive seen) why didnt thay help implement one of there AWD systems into the C7 for those who want AWD A on demand AWD system would put the Vette in a new league. Hows this for a C7 opening commercial. Its a snowy day and out from the white cloud of snow you see 2 headlights. As the lights get closer you here the sound of the new LT1 engine. Then the new C7 swooshes by. Then the words "C7 AWD THINGS HAVE CHANGED" appear on the screen. That will blow peoples minds :D As for using the Haldex AWD system Caddy uses, I would guess the Corvette folks would look for something a lot more robust and less complex and way lighter...however you get all that! |
Covette 2wh drive Vs. Corvette 4wh drive?
Four wheel drive traction really helps the front engine designed cars over the 2 wheel drive. The Porsche 911 2wh drive has always been quickly in 0-60 & 1/4 mile runs than the C4. This is different from a possible AWD Corvette. The rear drive/rear engined 911 doesn't have axle tramp problems like front drive cars do but the C4 was always heavier than the C2 so the C2 was quicker and still is today.
The Porsches really accelerate coming out of a turn. By the time the Corvette overcomes its lack of traction coming out of a turn the vette catches up to the 911 in the straights due to its torque. This action is very easy to see if you have ever gone to an ALMS race. Therefore, the Corvette would benefit more with AWD if all parameters are still the same as in the C6. Don't know about the C7 and the lighter weight and movement of more weight to the rear of the chassis, etc. The WRC Audi was originally quicker in 2wh drive over the quattro until the balance and weight improved & then the quattro really tore up the WRC racing world all other parameters were the same as far as Hp/torque/gearing. I was always instructed by my racing mentors that front engined race/track cars will be better with AWD as compared to the rear wheel drive. Overall as Jinx states, there are just too many variables to compare the FF vs. the F12. Obviously weight & traction are difficult to compare unless everything else is the same such as Hp/Tq/gearing/chassis, etc. Sorry for the long comment. Everyone already knows all this anyway. I would be interested in a C7 with AWD only if they could keep the weight of the AWD system to 120 pounds like Ferrari did, otherwise just give me RWD with excellent tires and less weight. Cheers, :cheers: |
(Post 1582292729)
:cheers: |
(Post 1582291354)
Blue Ox,
