Z06 Front Brake Duct Install on Base C6
Hi guys, I have a 2007 base C6 (Z51-optioned FWIW) and purchase Z06 front plastic brake cooling ducts just as quite a few on this forum have. After lining up the tube on one side, it doesn't appear that this mod is going to do anything to help cooling -- just common sense as the duct opening is a foot away and above the center of the rotors when bolted to the frame. :(
I searched Z06 front brake duct images and saw that the Z06 has a flex hose that connects from the end of the ducts to the center of the rotor. Is that something I can do? Has anyone else done this? Am I wrong in thinking this mod won't help w/o the flex hose? It is a cheap mod but I feel like it is a waste of time at this point. All input appreciated! Thanks! :cheers: Dan |
I used some vacuum tubing laying around to help direct flow. I was going to make a bracket to hold the tube right to the rotor but got lazy
https://sphotos-b.xx.fbcdn.net/hphot..._6484730_n.jpg |
Sinister, thanks much for the pic -- that helps.
I could get a couple of metal "L" or "Z" brackets and better place the duct near the rotor center. I may play a little while the wheels are off. |
Originally Posted by DannyBoyC6
(Post 1582073751)
I could get a couple of metal "L" or "Z" brackets and better place the duct near the rotor center. I may play a little while the wheels are off. This is what quantum makes: http://donymo.com/pics/duct1.jpg The tubing is aircraft silicon which im sure is expensive but not the $200+ companies charge for one of these kits. I tried a leaf blower to the inlet in the bumper and surprisingly a lot of air gets to the rotors |
Originally Posted by SinisterC6
(Post 1582073829)
np, next time I have the rotors off ill drill ill drill the hub and mount a piece of steel to which I can attach the tubing
This is what quantum makes: http://donymo.com/pics/duct1.jpg |
Thanks for the replies, guys. I have some resources at the job, so I may go rummaging to see what I can do without getting into triple-digits on cost. I'm hitting the track in 2 weekends and would like to get this buttoned up (and actually useful) by then. :)
FYI, the Z does NOT have hose going to the rotor from the factory. The duct is @1ft away like you mentioned on the Z from the factory too.
Originally Posted by LEAVINU
(Post 1582078919)
so anything i connect on the end of the duct is going to be better than the stock setup of the Z cooling... |
(Post 1582079108)
I also added the Z brake cooling ducts to my Z-51. I did not connect any hose though. I did a track day at Thunder Hill which has 3 very hard braking zones, and did not experience any fade with the stock brake pads. I did however, flush the stock brake fluid out and replaced with Stop Tech racing fluid. Not sure which of these actions prevented fade, but something worked.
Originally Posted by Russkier
(Post 1582080344)
