How Many Z06 Owners Are Running Solid Stainless Exhaust Valves?..."THE REGISTRY"
Like the thread title says, some of us thought it a good idea to get a feel for how many on this forum have changed from the OEM hollow stemmed exhaust valves, over to a solid stainless exhaust valve.
Here's what it looks like so far: Count is 414 C6 Z06 owning CorvetteForum members who have previously switched to, currently own builds or have builds in progress which will be running, or have experience in their LS7s with running, "heavier" than stock exhaust valves and "upsetting" stock valve train dynamics and "slaughtering" their redlines. Be they doing it with Inconel or Ferrea Super Alloy, Ferrea's new partly drilled exhaust valve, or Solid stemmed stainless steel, in stock or aftermarket castings. *******This thread as it is set up, is intended to be informative. So to that end the names are hyperlinked to prior posts describing key elements of the owner's build, to include, but not limited to, the cylinder heads in the car, and components used within them, ancillary modifications, and in most cases, which professionals were involved in the builds. The listing is broken down alphabetically, numerically, and geographically. The listing is a "Global" listing, in that it includes cars from parts of the world outside of the United States. The CorvetteForum, is the largest Corvette Centric forum of it's type. This fact should give the reader an indication as to the extent the use of this technique goes in the management of the LS7 stock valve drop issue. Owners and those interested in this topic, may study the listings and the wide range of information contained within the hyperlinks and using it, make what they deem to be the appropriate professional inquiries with regard to this matter. This method might save the viewer the trouble of wading through the BS and distractions, which typically come from those who agree with GM's selection of the stock, thin walled, hollow stemmed factory LS7 valves, despite several cases in here documenting their failure. Indeed, had you not heard of the failures of the stock LS7 valves, well you probably would not be in here. At any rate, the following listing is set up for your perusal. Use it to your advantage. As you study it and absorb the information, speak with professionals who have familiarity and actual practical experience with this technique, the use of non sodium filled SS exhaust valves in the LS7. Good luck, and enjoy your perusal of the listing which we who have taken the steps to avoid a windowed engine block due to a failed stock LS7 valve, fondly refer to as "The Registry". Ricky J ('06 Quicksilver Z06) A Achilles97 adamgl Aeons 2008 + andy82 Aedwardsix airindia33 2007 Alberta_Z06 andreas g. Andy K ANGRY Z anth115 2006 AreOhBeeC6Z avenger88 azZ06Mike 14 (1) B badassf4i Badddz06 BadZ Ferrea Super Alloy BAD_TCR+ BayAreaSS barneygookle382 baro0k@eXtermination + Mast Beach Bum+ Ben01C5 big_mike_eu 2008+ blackc6z blackbelt 2006 + Blacktavert 2008 + BLKBRD69+ Blue by u BLWN427 BgBoost1 Bonnets02Vette 2006 + Boscosz28 BoostdM3 Boosted Josh+ BosnianZ06 2008 + bowtiguy Brian@RPT briancb1 Briansshop BSheppard busaetr Buddy A Burnin4 bryandwightharris@gm bx goat 32 (10) C C5FRCpewter 2006 + C6 Curtis CamzillaZ Canuck Captain Z carbonite77 cdngolfer chetly+ 2007 CHIWS6 chadyellowz06 Chris2000 CHOPPER1 Cidz06 2006 + circuswings CobraAaron cobrasmith Cvette713 C5Lion C54CSTER C6Zhopeful393 C_Williams@RPM E Force Build Chevybob Chonger 2007 + ClarksZ06 Clogan Corvee colts95ta 2007 + Cozmo ctsv510 2006 + Cvette713 30 (6) D dannboss darkbluez dascorcher21 DaytonaFIC6 dcamick 2006 + Deadfast DelaWhere 2008 + Despicable Z+ inconel dfinke23 dkal70 2006 + donatez06 double06 2006 + Ferrea Competition Plus SS Exhaust Valves F2042P D-Rod Drazga Dre01SS DSKREET 2006 + Dsteck Dirty Howie drfeelgood duff1857 Dugmole duhveed+ DUMAN 2008 dvandentop 24 (7) E Ecs vette82 2008 edmundu EnginerdVT 2008 + Mast erichg1000 eroc022 Evil427 2 builds Ferrea Ferrea Superalloy in the first, and currently Ferrea Competition Plus SS Exhaust Valves F2042P + Evilness EvilZ51 Evolution-ary 2007 + extents EX1 11 (3) F Falcon Tech Famous RR Fartpipe FASTBLUEZ06 Fifedogg FNQWK fperra Ferrea Super Alloy felo357 fly a Z06 fowl69 2006 FrankTank FRChilln FRDnemesis FreakC6Z06 FSTFRC FreeBoost Funkybird FU 2006 f8f2Bearcat 19 G Gannet ghoust Godfather Gigapunk GIO-305 GMuffley go_mer greatone61+ GregK Griffee 10 (1) H hapnermw harrydirty+ harveyjl Inconel hass121 HCICC6Z Header Hercules Rockefeller ht600 Ferrea Superalloys hoefi HornZ htvette HyperX 12 (1) I IanM ibleedgreen icrashevos iNeedSpeed InflatableDog ioutrun ipmtim IrishC6 8 J Jawnathin jbvaldez JChastain jconnors316 2008 + Ferrea Competition Plus SS Exhaust Valves F2042P JCox23+ 2008 JDIllon Katech Street Attack j hebert jedblanks jeffreystar Jeremy@RPMTransmissions jimbob8915 jnv255 JJFormato jkrlucas Katech Street Attack LS7 with Ferrea Super Alloy exhaust valves and bronze valve guides as of 1/13. jmerola jmorgan07z06 2007 + JMNZ06 2007 + jnel04 2006 + jnv255+ JoesC5+ johncbourg jophis37 JsnMR52 Mast Justinlamanna Mast jtjohn1 Ferrea Competition Plus SS Exhaust Valves F2042P 2009 + JwT JWY Z06 27 (8) K kamafnkazi 2007 + Keith N KentZ06Ferrea Super Alloy kenw 2009 + Ferrea Competition Plus SS Exhaust Valves F2042P KillerFRC KLLRVET Kotik 2008 + Ferrea Competition Plus SS Exhaust Valves F2042P 7 (3) L LanceFitzgiben lane_change Lawdogg lawman34203+ lebvette 2008 + Leroy 07 z06 2007 + Les-10 2008 + Let It Rein lilredvette05 LMBTom LMB-Z 2006 + LOUFY LowETz LS7 Bud LS7 Drew LT1Pat 2006 + LT5 John lucki86 LUV2SPD Lynch Z06 2009 + 20 (7) M Macattack Madsen MAG STAR Mangum+ MarkC mariofromnewyork Matt Clawson Ferrea Matt-P 2009 + mazeroth mdaniel Meanjoe Ferrea Superalloy meatheadgn Mike06Z06 Mike.D Mookster Ferrea Superalloy. msd127 Mudcrutch MudZ06 Myhardtop MySelfAffliction 20 (2) N NachosZ06 NavyAirTraffic Ferrea Competition Plus SS Exhaust Valves F2042P 2007 + NC_427_Vert* NDAGRUV 2008+ nd3 Nick 02 Z06 NJKGR8YT NO CHNCE No4Play NO SHOW 2006 + NWbluez06 Ferrea Super Alloys, 25K miles. NY06Z06 Manley HD EX1 nyerby 14(3) O OJCrush08 oldcrow471 Omega Man 2006 + ONESLOWZ0 video onthjug 2008 OrangeSix 6 (1) P parsonsj Inconel patch68 2006 + Peter Clark 2006 + PeteZ06 phatbeatnut philpacs phipp85 2011 + Ferrea Competition Plus valves phxcobra pomppe prr1 video Property1! pwnall1331 2008 + 12 (4) Q qnitro 2006 1 (1) R Racie Racin Z06 racetoy ralphsmithiii RamAir972003 rattt g RedZ4me RGT richy rich Ferrea + 2006 rio95 2007+ Roadtrip120+ RichieRichZ06 ripptide56 Rick@RKT56 Rock36 Rupertpupkin 2007 + RWE 427 RyneZ06 rzmnco 19 (4) S Samatbama 2008 + savaGe sanstackie665 scemo start 1SLEEPYZ SlowestZ Scuba_Steve scottss Ferrea screaminchevy See06 seung012 setxws6 Sicc siksvt03cobra silvrhand + 2008 Sixbills skywalker SlowVet05+ Sm5654 SmokinZ softy91 Ferrea soldier4life SONKIST 2008 + spicytuna spdmn75 sriser 2009 + SS MPSTR ssracer337 SSMOKE Stage Runner stangeater01 stanger383 stano starchedup starr1 Ferrea Competition Plus SS Exhaust Valves F2042P 2008 + stepa j stew1100+ Stroker_9 2006 + svre46 svtgeoff SVTLOL szaro1 2007 42(8) T tail_lights+ The Devil Z TheDingo+ Tfavor2007 The_Ruski_Driver 2008 + TJ@RPMtransmissions tjwong Ferrea Super Alloy torqjunky ToppThat track junkie trackpilot Track Z06 Manley Severe Duty Treadhead+ triblk6spd Troy6166 Ferrea Competition Plus SS Exhaust Valves F2042P 2007 + TRSCobra 2006 + Trudat 2nd car with SS valves. Trudat One with over 30K miles on it. TT32VGT tt350z Turbo2L 2008 + Turbo Kid Turbosixx turbotank 2006 + 24 (8) U UBNZO6D Uncledibble Undy Unreal 4 V VetteFish veilseven 2007 + venomous-v VETTETHREAT 2007 + VictoryRedZ06 5 (2) W walhan_qtr wesellit WhiteDiamond WhiteKnight 2008+ whtturbot@aol.com Witt748 wjrive 2010 + Woz Z06 8 (2) X XDemonX Xplosive Performance 2 Y yankee15 2007 + Ferrea yellowzron yfzkevin youzzi714+ yuniel 5 (2) Z ZedNought6 2008 + Z O SICK zoomz Zoxxo z06king Z06 Steve 2006 + z06tx Z06_505 z0sleeper zman62 zuli Z2Z 12(2) # 1SLOLT1+ 02magred 02sscamaro '06 Quicksilver Z06 07_r1 06-Z0SICK Ferrea Super Alloy 08VRZ06 1Sikstik 1stZ 12 oh 2006 2000FRCZ19 2013 Z06 2013 + 1badassz 1z062nv 10gt5 + 2008 427ZM 50 4Ever 619grappler 66L72 69dodgecharger 69 Vette Mast 240sx2jz 2V4NOW 66biskwik 95jersey 1981turbota 26 (3) Now lets get an idea of which states, territories, and countries are represented. So if your state shows up in your profile, signature or avatar, then you are listed under your respective state, territory, or country as well. Alabama BSheppard EvilZ51 stew1100 Samatbama Alaska American Samoa Arizona AzZ06Mike Evilness jophis37 NachosZ06 phxcobra SlowVet05 Arkansas lilredvette05 08VRZ06 lebvette California andreas g. Dirty Howie C5Lion C_Williams@RPM C54CSTER MAG STAR FamousRR Zuli fly a Z06 InflatableDog Jawnathin DUMAN Keith N LS7 Drew Nick 02 Z06 JMNZ06 RGT RichieRichZ06 SS MPSTR Stage Runner UBNZ06D VetteFish ZOXXO 50 4Ever softy91 619grappler RyneZ06 69dodgecharger VictoryRedZ06 savaGe youzzi714 Treadhead Chetley Evolution-ary qnitro Colorado bowtiguy walhan_qtr Scuba_Steve erichg1000 Connecticut Delaware DelaWhere District of Columbia Florida BadddZ06 chadyellowz06 Gannet GIO-305 Sixxbills C6 Curtis Parsonsj LT5 John BLKBRD69 ralphsmithiii trackpilot zoomz Georgia ANGRY Z racetoy SLEEPYZ badassf4i ibleedgreen mazeroth jnv255 drfeelgood Falcon Tech phipp85 Guam Hawaii Idaho Illinois HyperX Witt748 yellowzron ToppThat PeteZ06 Woz Z06 FrankTank CHIWS6 Turbo Kid z0sleeper Blacktavert big_mike_eu Indiana TJ@RPMtransmissions C6Zhopeful393 Macattack DaytonaFIC6 Iowa KLLRVET Kansas Kentucky Header Louisiana blackc6z J Hebert ssracer337 troy6166 Turbosixx Maine Maryland rzmnco Rick@RKT56 double06 Massachusetts edmundu Michigan OrangeSix rio95 Minnesota Lawdogg ramairws6 HornZ Mississippi Scottss JwT Missouri adamgl barneygookle382 BgBoost1 DSteck track junkie dascorcher21 Montana Nebraska Sicc Nevada New Hampshire 02magred New Jersey avenger88 FASTBLUEZ06 IanM jmerola ratt g LUV2SPD New Mexico LanceFitzgiben New York 66biskwik The Devil Z NY06Z06 bx goat Aeons Z06 Steve North Carolina felo357 Mark Clawson NC_427_Vert 1SLOLT1 VETTETHREAT HCICC6Z C5FRCpewter North Dakota Northern Marianas Islands Ohio MudZ06 GMuffley NO CHNCE Mudcrutch starr1 Oklahoma Boscosz28 Leroy 07 z06 Oregon tjwong Madsen Pennsylvania Fartpipe wesellit 2013 Z06 dcamick Puerto Rico Rhode Island South Carolina FRDnemesis South Dakota Chevybob dvandentop veilseven Tennessee Blue by u Texas BADZ BAD_TCR Beach Bum Brian@RPT Buddy A EViL427 kamafnkazi screaminchevy Cvette713 Corvee Cozmo No4Play EX1 FST FRC htvette Meanjoe jedblanks jeffreystar IrishC6 Sm5654 lane_change LMBTom Mike06Z06 myhardtop NJKGR8YT Racie ripptide56 RWE 427 setxws6 spdmn75 torqjunky triblk6spd Omega Man z06tx 1badassZ WhiteDiamond stepa j KillerFRC Roadtrip120 silverhand LMB-Z jmorgan07z06 Cidz06 jnel04 Utah Unreal z06king meatheadgn Vermont Virginia Undy OJCrush08 MarkC kenw sriser Virgin Islands Washington fperra kentZ06 NWbluez06 Mookster TRSCobra West Virginia D-Rod Wisconsin Wyoming Canada Canuck British Columbia. msd127 saskatoon Saskatchewan, Canada 06-Z0SICK North Bay Ontario Z06 BUD Hamilton Ontario 66L72 Keswick Ontario cdngolfer King City Ontario nupsi Edmonton Alberta FreeBoost Calgary Alberta Albrerta_Z06 Calgary Alberta spicytuna Canmore, Alberta 1z062nv Toronto Ontario Europe jbvaldez Baumholder Germany Rock 36 Stuttgart Baden-Württemberg Germany nd3 Graf Germany 1981turbota Bavaria Germany pomppe Orivesi Finland Peter Clark Devon England Kotik Germany Middle East Cars which have suffered engine failures since around June 2012. I added this section to the listing for further informational purposes and I will be updating it from time to time along with the rest of the listing. 1. CGZ06 2009 stock 34,670 miles Dropped valve 2. Cyclone09Z06 2009 stock 18,200 miles Dropped valve 3. Jackal 2006 56,000 miles cam only Dropped valve 4. jmurf28 Stock 2006, 13,555 miles[/B] 5. fmcockc 39,000 miles failed on track Dropped valve 6. Gary Glasser 2006 Z06, dropped a valve at 40k miles 7. jad568 2007 45,000 miles failed while being backed out of parking lot 8. AreOhBeeC6Z 29,000 miles, bolt ons 9. Daniel Hoffele 2007 49K miles CAI, Catback, stock tune. 10. philpacs 2006, 30K miles 11. turbo50mike 2007 no prior mention of the incident that I can find before the hyperlinked thread. Dropped Valve. Replaced engine under warranty 12.*DaWizard Dropped Valve 13.*kawaiilaosboy Dropped Valve 14. z0silk 2007 55,000 miles engine replaced under warranty after dropped valve. 15. Vividz06 '07 30K miles 2 hrs on a track 20k later. 16. boost2na '09 17,300 miles. 17. dsharkman '07 17,775 miles. Billy Boat Exhaust and a Halltech Killer Bee intake. 18. jph331 '07 86,000 miles. Lost a valve into the #1 cylinder. Unknown if it was an exhaust or intake valve. 19. Stanger383 '07 20,000 miles. 20. The Black Bitch 2008 30,000 miles dropped exhaust valve. 21. punchz06 2009 Dropped stock exhaust valve, 27,000 miles. Headers, custom grind cam, new springs, vararam intake. 22. Madsen 2006 10K on a cammed motor, dropped a SS valve running OEM stock powdered metal valve guides which were completely shot. This after having dropped a stock exhaust valve several months prior. 23. Corvee Bent a SS valve which went on to break. 24. qtr_c6z06 2008 20K miles, unknown failure. Windowed block 25. zamora7 2007 36K miles. Windowed block. 26. BEZ06 2006 47,000 miles CAI, Tune. Very large hole in block. 27. kattigrr 2009 40,000 miles bone stock. Broken exhaust valve pics. 28. jbednarsh 2007. 29. cantevendrive75 dropped valve. 30. Slacker1201 2012 10,201 miles, #5 & #6 rod bearings. 31. CWW17 2007 52,000 miles. 32. rstandke 2009 Dropped Stock Exhaust Valve, 23,800. 33. AmitZ06 2006 52,000 miles 34. Radbrooks 2009 41K miles, oil starvation. 35. theseal 2008 bone stock, dropped exhaust valve, at 61,000 miles. 36. o6zo6vette 07 38,574 miles failed piston. 37. quicked 2007 less than 9,000 miles on car. Cam only setup. Broken stock exhaust valve 300 miles later. 38. NotVincent 2013 427 Vert. 5,000 miles. "connecting rods did not have enough clearance and ground bits of titanium into my oil" 39. LittleBlueBMW 2009 Dropped Valve at 26K miles. Stock except for upgraded brakes and tires. Failure occurred on track. 40. Dallas 123 2008 cam, headers, dropped 2 valves while cruising at 2200 RPM. 41. j zammy 2008 40K miles dropped valve during normal driving. 42. Donny07Z06 2007 42K miles dropped valve. 43. richie427 2007 35,000 miles dropped valve Pic 44. panos dropped exhaust valve. 35,000 miles 2008 45. bstedman 2006 51,000 miles dropped stock valve. *Described SS valve failures, aftermarket cylinder head mishaps, and misadventures. * Missed the start of the thread cut, but only by days. ECS videos. Other videos. 10..8/9 7/6 3/7 0/0 25 |
I've been running Ferrea Super Alloy exhaust valves for 14K miles so far. I changed the guides about 3K miles ago. No wear on the stock guides was found.
PRC 285CC heads with SS exhaust valves, TI intake. 1500 miles on them so far no issues.
Stock heads were pulled at 28k and all 8 exhaust valves/guides were way out of spec. |
running SS exhaust valves and the tumble polished intake valves from WCCH's most recent head work.
With Ferrea springs.
Heads getting reworked by WCCH with SS exhaust valves, tumble polished intake valves, and bronze guides.
ss here
Originally Posted by EViL427
(Post 1581929631)
Who else has SS exhaust valves and have checked them 10k miles or more after installing them? |
SS here
Ferrea Super Alloy exhaust valves here with bronze exhaust guides
Uh, how many ZO6 owners know better roller cams (mechanical and hydraulic) are manufactured from carburized 8620 alloy steel billet cores that have a superior surface (and subsurface) durability that prevents spalling (particles flaking --typically 60° down from the nose of the cam) that can be found on 5150 alloy and other cam cores?
I'm inclined to defer to GM's engineering talent on LS7 valves and related materials science expertise. The conspiracy theorists flogging LS7 valve train deficiencies are need to move on ... |
SS ex valves and bronze guides here, 2.5k miles on the setup so far no stumbles...
I've been running ss exhaust valves and OEM intake valves for about 14k miles.
I've been running SS exhaust valves, bronze valve guides,and OEM intake valves for about 3500 miles.
Originally Posted by Raisin Man
(Post 1581931029)
I'm inclined to defer to GM's engineering talent on LS7 valves and related materials science expertise. The conspiracy theorists flogging LS7 valve train deficiencies are need to move on ... I'm trying to get a count here of Z06 owners currently on this forum who run solid stainless steel exhaust valves, or bronze valve guides and stock hollow stemmed exhaust valves. If you want to debate GM's engineering talent on LS7 valves and related materials science expertise, then start your own thread. Thank you. |
I am running SS exhaust valves and the tumble polished intake valves with bronze guides from WCCH with 4000 miles on them. At 12,500 miles my stock exhaust guides were out of spec
I have Ferrea SS, stock Ti with stock guides. Heads were from an '08, with 2k miles when valves were replaced. Guides checked out fine, so they were left in. I have about 1.2k on them now. No issues so far.
Oh, and the OP bought my oem heads, which apparently showed that I made the right decision to pull them off when I did... :cheers: |
Originally Posted by edmundu
(Post 1581931798)
:seeya
REV SS Here. 2 years no issues! |
Originally Posted by BgBoost1
(Post 1581932113)
:seeya
