FS/FT:2006 Corvette 30k miles NEWPICTURES
2006 Corvette M6
30,XXX Comp Cam Kooks 1 7/8 long tubes Borla X pipe with 2 electric cutouts Fast 92 Ported to match heads Ported and Polished heads with Valve job Ported Throttle body Custom Dyno tune Harden chromoly push rods Comp cam roller rockers 313 LBS springs Titanium retainers 6 speed manual 20x11 and 19x10 CCW 505As Pioneer Head Unit Z51 Brakes with braided lines 160 thermostate Center console color matched Here is some specs on the engine from the shop. Head porting services by Gressman Powersports. Includes runner, bowl and chamber porting, competition valve job, mill to clean, flow testing on Superflow flow bench, cleaning and reassembly with new valve seals. Camshaft, Hydraulic Roller Tappet, Advertised Duration 281/283, Lift .571/.573, Chevy, Small Block, LS1/LS2/LS6 CCA-26918-16 Valve Springs, Single, 1.055 in. Outside Diameter, 313 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16 CCA-13755-KIT Rocker Arms, Stud Mount, Full Roller, Steel, 1.75 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, LS1/LS2/LS6, Kit CCA-7955-16 Pushrods, Hi-Tech, Chromoly, Heat-Treated, 5/16 in. Diameter, 7.400 in. Length, Universal, Set of 16 CCA-772-16 Valve Spring Retainers, Titanium, 7 Degree, 1.055 in. Outside Diameter .640 in. Inside Diameter SLE-12505 Gaskets, Cam Change Set, Chevy, Small Block Gen III/IV, UPI-2111 Valve Cover Spacers, Aluminum, 0.500 in. Tall, Chevy, Small Block Royal Purple 5W-30 6 FRAM-PH2 Fram Oil Filter PH2 I have all the factory parts that go with the car as well. The dyno sheets, shop contact info who built it, flow sheets for the heads. Never has seen snow I have to many cars and barely drive it anymore.The car had around 9K miles on it when the cam was installed and all other mods where done. I am asking $30K for everything. I am the second owner car has black leather. Open to trades Title in Hand Thanks Rich http://s1299.beta.photobucket.com/us...88796209899277 http://s1299.beta.photobucket.com/us...81125069962565 http://s1299.beta.photobucket.com/us...81528069633913 http://s1299.beta.photobucket.com/us...04717940366159 http://s1299.beta.photobucket.com/us...98292791886595 http://s1299.beta.photobucket.com/us...04437502441513 http://s1299.beta.photobucket.com/us...30183337626356 |
Nice car... Almost bought it! Rich, post the total miles.
My computer will not allow me to upload pics. PM me if interested I can send you some.
Originally Posted by firefighter813x
(Post 1581636272)
Specs on the cam?
Location of the car? Send pics to ridezx6r@gmail.com and I'll host/post them for you. |
Originally Posted by RideZX6R
(Post 1581638021)
Specs on the cam?
I am interested.. can you send pics to hoytrb@gmail.com
All PMs and emails sent thanks everyone.
never received pics - send em if you want me to host em, somewhat interested in the car as well
ridezx6r at gmail |
(Post 1581644082)
ridezx6r at gmail |
Originally Posted by SLOW06!
(Post 1581644384)
Did you receive the video? I sent the pics and video about an hour ago....maybe gmail put it in the junk folder? I am sending them again now. Thanks for the help
(Post 1581645003)
It all came in twice within 3 mins. I'll upload them when I get home from work after 5pm.
14 Attachment(s)
Sent you an email about the car... here are the (not resized but thumbnail linked - sorry) pics...
Attachment 48378696 Attachment 48378697 Attachment 48378698 Attachment 48378699 Attachment 48378700 Attachment 48378701 Attachment 48378702 Attachment 48378703 Attachment 48378704 Attachment 48378705 Attachment 48378706 Attachment 48378707 Attachment 48378708 Attachment 48378709 |
(Post 1581645465)
good info... we gotta figure out the duration at .050
Saturday bump
All PMs replied to.
I am willing to put the car back to stock. I have every part that was removed from the car down to the radio unit. I have the factory wheels and tires as well, brake lines, pads, rotors, push rods, rocker arms, springs, retainers, intake, exhaust and so on.
All PMs replied to
