Originally Posted by Burnt71
(Post 1582652544)
It should be there I'll look after Christmas
I am looking for a part for a 1980 Corvette with air. The part I am looking for is located behind the right front fender just ahead of the door. It is a tunnel that allows air to enter the cabin at the passengers feet. I do not need the vacumn pot or the door, just the plastic tunnel that the door fits into. Might you have one? and if so how much? and shipping to 37643 TN. Also looking for a working rear defroster switch Thanks, JOHN Did you ever get a chance to see if you still have the vent piece and defroster switch? Thanks, John |
Need the rear-end. still available?
(Post 1581349086)
Cut out for an aftermaket radio
Do you still have this? Can you send me a pic & how much? Thanks, Fred |
Do you still have the dash?
I'm looking for the rear side wrap around skirt ground effects
they go from the rear of the rear wheel and wrap around under the rear bumper pm me portolet1@yahoo.com thanks jeff |
Looking for used radio antena wire from powered antenna to radio. Do you have one still on the car?
Originally Posted by pwcheenie
(Post 1582981137)
(Post 1581321678)
on wheelwell hump , back interior
(Post 1582987295)
**edit** I bow down....I checked mine, and I was wrong. It definitely goes to the T-top strap. Most likely on a wheel hump. Check on the wall behind the seats, it could also go there. |
back hump...
It was a pie plate :D
Originally Posted by TurboStitchCW
(Post 1582988009)
You sure? Compared to the plate, it looks kinda long. To me, it looks like the seat belt guide that goes under the seat in the retractor compartment.
Its for your T-Tops
Originally Posted by xpocdude
(Post 1582995390)
Its for your T-Tops
Where would it go on the T-Tops? Take a pic |
Originally Posted by MarkBullis
(Post 1582995805)
http://img.photobucket.com/albums/v3...rrightshot.jpg |
do you by chance have the motor and tranny
Do you by chance still have the bezel around that wiper switch? That's the box shape that protrudes from the dash around the switch its'elf.. Gary .. gt43506@yahoo.com I'd be happy to call and talk you through it.
Do you still have the heads?
If you do how much are you asking for them?
Thanks Dave C. |
Originally Posted by eagle575
(Post 1582998571)
