FAST 92 Intakes are back! In black!
FAST LSX 92mm Intake Manifold (LS1/LS2) $849 shipped
In stock! Part# 54039B http://www.hinsonsupercars.com/image...large/1468.jpg New black version of the FAST LSX 92mm Intake Manifold delivers proven bolt-on performance gains and new eye-catching appearance. The patented LSX™ 92mm Black Intake Manifold from FAST™ is the only three-piece Gen III (cathedral port) composite manifold proven to deliver increased performance without compromising bottom-end drivability or high RPM power. For both street and racing applications, the new black intake manifold is an easy bolt-on installation for GM Gen III (LS1, -2 & -6) engines and is designed to work with the FAST™ Big Mouth 92mm Throttle Body™. The new FAST™ LSX™ 92mm Black Intake Manifold maintains the performance gains achieved over stock intake manifolds with no loss in drivability or low RPM torque. While the new stylish, black intake manifold delivers terrific performance right out of the box, it can be ported by the customer for even more flow. As requested by previous LSX™ customers, the intake features the added benefits of corrosion-free stainless steel assembly bolts, an improved throttle body sealing flange and o-ring gasket and threaded insert throttle body mounts that provide increased durability. Features & Benefits: •New “Black” Gen III intake manifold with 92mm throttle body intake opening & added refinements •Improved throttle body sealing flange & o-ring gasket •Includes stainless steel bolts, threaded insert throttle body mounts & mounting hardware •Incorporates high-quality polymer materials, which resist “heat sink” effect of aluminum •Maximizes potential of other popular engine performance upgrades such as cylinder heads •Designed to work in conjunction with the new FAST™ Big Mouth Throttle Body™ (92mm) Part# 54039B |
Oh you mean to tell me used to shi! 90's aren't gonna go for $950 anymore??
Please do everyone a favor and post this EVERYWHERE! |
Originally Posted by FRiCK916
(Post 1581241742)
(Post 1581241742)
How much more is the throttle body?
Is it really much diff then the prievious fast92?
awesome, yea i cant belive the value of the used 90's and 92's still..i see them for 1000.00 900, used wtf!!?? and the new ones come in blk that looks awesome.
Originally Posted by G.Rossman
(Post 1581252153)
GM LS3/LS7 90mm Throttle Body - $189
Originally Posted by MX621
(Post 1581252697)
Thanks |
Whats is the difference between the GM LS2 90mm Throttle Body & the GM LS3/LS7 90mm Throttle Body?
Originally Posted by Damier
(Post 1581293861)
(Post 1581293861)
LS2 http://hinsonsupercars.com/images/Product/large/974.jpg LS3/LS7 http://www.hinsonsupercars.com/image...large/1465.jpg |
Originally Posted by fatlt1
(Post 1581255760)
Really nice look!
Anyone have before/after Dyno data on this mod without upgrading heads and cam? :cheers: |
Now if they would have only taken the internal shape improvements from the 102 and put them in the 92.
Originally Posted by HinsonSuperCars
(Post 1581271253)
GM LS2 90mm Throttle Body - $469
GM LS3/LS7 90mm Throttle Body - $189 |
from what i understand the ls3/ls7 type 90 will not work with the ls1/6 something to do with voltage. it just doesn't work right.
Originally Posted by Cardinal Flyer
(Post 1581349904)
Really nice look!
Originally Posted by JIMS SVT
(Post 1581358672)
Will either oneof those tb's work on a C5 without any weird electrical issues or harnesses?
Originally Posted by stryderss
(Post 1581364197)
I understand that with the original Fast92 the back of the motor had to be lowered slightly for clearance. Is this true with the new one?
Originally Posted by rnelson11
(Post 1581439373)
Thanks for your orders!
