Ragin Racin Stage 1,2,3,4 "SALE"
Ragin Racin is offering a parts package for all performance levels. All the parts you need to bring your performance up to your desired HP levels. Put a little Rage in your Vette, Remember "If you're not Ragin you're not Racin"!!
Stage 1 Honker CAI Ragin Racin ported intake and throttle body* 160 stat $725 Z06 add $100 Stage 2 Honker CAI Ragin Racin ported intake and throttle body* 160 stat Long tube headers $1765 Z06 add $100 Stage 3 Honker CAI Ragin Racin ported intake and throttle body* 160 stat Long tube headers Ragin Racin cam of your choice Pac dual springs Pac TI retainers Pac spring locators Crank bolt timing cover gasket 2 water pump gaskets Crank seal 2 valve cover gaskets $2895 Stage 4 Honker CAI Ragin Racin ported intake and throttle body* 160 stat Long tube headers Ragin Racin cam of your choice Pac dual springs Pac TI retainers Pac spring locators Crank bolt timing cover gasket 2 water pump gaskets Crank seal 2 valve cover gaskets Ragin Racin ported heads* head bolts 2 head gaskets $3850 For details please call 337-278-8397. * We port your core. |
Cam choices:
LS 1,2,6 Camshafts Stinger 224/232 .625/.625 113 1800-6800 rpm powerband Exlellent low end torque and midrange power with excellant street manners. Undertaker 224/232 116 Off idle-6800 rpm power band Stock drivability with a very minor lope. Excellant stealth or blower cam. LS1 Blower 220/230 114 Off idle to 6800 rpm very nice idle and drivability to maximize performance inr boosted lsx. Shreader 228/236 113 2400-6800 rpm powerband Excellant midrandge cam with decent drivability. Choppy idle. Distroyer 232/242 112 2800-6800 rpm power band Great top end power. Some surging at lower rpm's. convertor required. LS3 Stinger 224/232 .625/.625 113 1800-6800 rpm powerband Exlellent low end torque and midrange power with excellant street manners. Intimidator 224/240 113 1800-6800 powerband excellant low end and with a good top end punch. Real good drivability. Nice choppy cam idle. No convertor needed. Avenger 228/244 112 2000-6800 rpm powerband Great mid range and top end power. Choppy idle Convertor required. LS7 Sleeper 222/242 114 off idle to 6800 rpm powerband Excellant torque Like stock drivability very mild idle. Stalker 224/246 115 1800-6800 powerband excellant power through out great drivability Choppy idle Lethal 232/250 113 2400-6800 rpm powerband Excellant med range with a great top end punch. Minor low rpm surging. Nice choppy cam idle Punisher 236/256 111 2800-6800 rpm powerband Good mid range and excellant top end power Very choppy idle Striker 240/260 109 3000-7000 rpm powerband Great top end punch very choppy idle Blower 1 224/248 117 Very efficient with slight cam sound to idle Stock drivabilty Blower 2 232/256 114 Choppy idle for larger blowers Some surging at lower rpm's LS9 ZR1 ZfoRce1 224/250 115 nice choppy idle with good drivability |
Still going!!
Thanks for the sales!!
Free shipping for the week of the July 4th.
Does stage 2 include xpipe and cats?
It has an off road x pipe.
Sent pm or tried, on my phone, how much for the stage 2 with catted system and what is the turn around time on the porting?
Pm sent
Appreciate the sales!!
Appreciate the purchaces!!
http://i29.photobucket.com/albums/c2...vectorized.png
Randy Leger 337-278-8397 sales@raginracin.com http://www.raginracin.com |
Thanks to all who purchased last month. Appreciate you.
Randy Ragin Racin 3372788397 |
Appreciate the purchaces!!!
Still going!!
Thanks for the sales!! http://images.ibsrv.net/ibsrv/res/sr...es/cheers2.gif
We will be closed this weekend to move into our new facilaty. We will be open Monday at 9 am at 209 Harold Gauthe Dr in Scott LA.
