Originally Posted by meine96ws6
(Post 1584780038)
Can i order it via debit card?
Received and installed :thumbs: the metal was bent in at one end (I assume by the postal service), may want to put a note listing as fragile on future shipments so this part that tends to see so much abuse once in place doesn't get off to a bad start before it's even installed :cheers:
:thumbs:
Just placed an order, can't wait to see my girl with the sides on. Thanks Corvettemods! :thumbs:
:thumbs:
Question for you..
Is your center air damn plastic as stiff as the oem plastic? (meaning is it pretty sturdy?).. I already have your LH/RH pieces and they were noticeably more flexable then the oem plastics... I need the center piece to be pretty stiff to help with an air flow issue I have.. I am ready to order the center piece and hardware if you can describe the rigidity of it. Thanks. |
Originally Posted by ajrothm
(Post 1585987862)
Question for you..
Is your center air damn plastic as stiff as the oem plastic? (meaning is it pretty sturdy?).. I already have your LH/RH pieces and they were noticeably more flexable then the oem plastics... I need the center piece to be pretty stiff to help with an air flow issue I have.. I am ready to order the center piece and hardware if you can describe the rigidity of it. Thanks. The center pieces is very rigid though. thx |
Originally Posted by corvettemods1
(Post 1585988043)
You want the sides to be flexible as they take the biggest hits on a turn. The oem's were flexible at one time also, but as they age they harden.
Standing by.
(Post 1587536833)
:thumbs:
I need to order one of these this spring... I got a tear in my passenger side...
I have a new cradle for my blower. Could I use the factory center piece still? For some reasons, the installer replaces with a bolted on piece that does not spring back from Procharger!
Originally Posted by Caveboy
(Post 1588710293)
:thumbs:
