Replacement Air Dams On Sale! **$89.99**
Every time you hear that "scrape" when you are driving your C5 around town, odds are that you are slowly eating up your lower air dam spoiler. The flexible plastic can resist this abuse, but over time it begins to warp, bend and ultimately falls off. If your air dam is currently warped or damaged, it is very important to have it replaced. The spoiler actually creates negative pressure under the car funneling the air to the radiator. In addition, a damaged spoiler will lead to hotter engine temps and reduced performance! :eek: If you haven't taken a look at yours yet, might want to before these sell out at this price. These are also great to have on hand when it is time for replacement (it will happen!):thumbs: Our offering is for the complete 3 piece air dam replacement kit that easily reattaches to the bumper with the existing hardware. Install can be done right at home! We have these kits available at the lowest price ever listed on the forum... $109.99! That's 20% off our already great price! Click here to order: http://www.corvettemods.com/C5-Corve...IT_p_5059.html http://i288.photobucket.com/albums/l...ody_damage.jpg http://i288.photobucket.com/albums/l...psd29970a4.jpg We also sell the left and right pieces as a kit here: https://www.corvettemods.com/C5-Corv...LY_p_5528.html And the center piece here: https://www.corvettemods.com/C5-Corv...ly_p_5529.html |
Just ordered this piece!
And the center piece here: http://www.corvettemods.com/servlet/...orvette/Detail Thank You! |
Originally Posted by Jayman
(Post 1581912526)
Can I just order the mounting kit for the center section? My spring / wire broke and now I am hanging by zip ties. Thanks
Originally Posted by jgump
(Post 1583225100)
Whats the reinforcement for the sides?
back in stock! :woohoo:
I'll be checking mine. I bet if I ordered those parts from Chevy, there would be a 1 in front of that $89.99. Do you have the left front inner fender? It's the section behind the tire.
Originally Posted by martysauto
(Post 1584360194)
Is the $89.99 price still good?
Originally Posted by Stang-etr96
(Post 1584361601)
Order placed, looking forward to freshening up the front end a little
Originally Posted by crazystevex
(Post 1584439547)
Mine looks to have attached to the frame by two bolts; it removed itself while I was driving home with the car and I was left with one bolt and a third of the air dam piece to try to figure out what the rest looked like. Are these two bolts the mounting hardware you are referring to or is there more that is added for my $14.99? Thanks.
Edit: I believe the only mounting hardware item I am missing is the second bolt, which I should be able to source from a hardware store quite easily. The two silver brackets that run from the bar just in front of the bottom of the radiator are still there. If I need nothing else, I'll just order the main piece. |
Originally Posted by rjwz28
(Post 1584728120)
Are the other bolts for the brackets? See edit... I just don't want to buy a bunch of things I don't actually need.
(Post 1584728354)
I ordered the center section alone, I believe all the bolts but the one are under there so it shouldn't be a problem :thumbs:
(Post 1584728462)
Can i order it via debit card?
