2008 LS3 problem
Upon returning from a 10 day vacation, the (new) battery on my 2008 convertible was dead. I charged it overnight, but all I get is a clicking sound when I try to start. I tried to jump it with my other car but still getting a clicking sound. The check engine light is showing on the dash.
Any suggestions will be truly appreciated! |
Battery has been abused to death. Disconnect battery and I bet it still won't take a charge because it is shorted.
If you already didn't do this when you changed the battery try cleaning the cable ends and battery and make sure they are reasonably tight, don't overtighten. Since you charged it overnight and had the same problem and it won't start when jumped I suspect the battery terminals or cable ends are the cause. It should start when jumped even with a bad battery but won't if the connections are bad. To be sure you can take your battery to an auto parts store and have them check it out if cleaning the connections doesn't help. You could also check the car body connection for the negative cable. Good luck.
in add. to above, ck to see (since it's a new batt.) that you have the proper cable nuts. they're easily lost when taken off completely (not necessary to do with batt. replace.) and if not on and tight, there's no completed circuit. finally, since you've been on here a year, you may want to read up on batt. "maintainers." if you ask me, it's very important to the life of your car batt.
LS3 won't start
Thank you guys for your quick suggestions. Just for clarification, my battery is 2 months old, Optima yellow top. The cables and connections are clean, snug, no missing nuts. Been driving the car with no problems until I left it for 10 days. Next time I know to plug in a battery tender.
I will have the battery checked to see if it's shorted, as suggested by Fort. |
Hope it all works out. Tell us, btw, if it is a failure of the battery. I doubt it but it could be.:cheers:
Sounds like you may have got a defective battery...get it checked out.
Originally Posted by Raymond44
(Post 1580941999)
...Just for clarification, my battery is 2 months old,...
Otherwise I'm back to bad battery even though it is only 2 months old. Be sure to let us know what you find. |
Originally Posted by boraxman
(Post 1580942300)
Bad Battery. Return it, that should not happen to a Optima Yellow Top.
Originally Posted by FortMorganAl
(Post 1580941619)
You were 100% correct...the 2 month old Optima Yellow Top is dead. The auto store checked it and replaced my battery, and my Vette is alive again. I must say, however, that the battery was never " abused". The car was just parked in the garage for 10 days, and it died. Next time I'll have a battery tender plugged in. Thank you all for your responses. |
(Post 1580944359)
FortMorganAl,
You were 100% correct...the 2 month old Optima Yellow Top is dead. The auto store checked it and replaced my battery, and my Vette is alive again. I must say, however, that the battery was never " abused". The car was just parked in the garage for 10 days, and it died. Next time I'll have a battery tender plugged in. Thank you all for your responses. I wont use them anymore, the last 2 I had died with in a year, both of my dads batteries in his boat died with in a year. I still to Sears AGM or Orielly's AGM now. |
(Post 1580941999)
(Post 1580944359)
FortMorganAl,
My 08 does not given driven a ton. When I bought it new it had 2 miles on it. Almost 5 years later and I have 6K miles and on the original battery. I leave mine on a tender when not in use. If it dies now, I feel I'm luckier than a lot of folks here.
(Post 1580944359)
FortMorganAl,
Originally Posted by Mike02Z
(Post 1580945755)
Got one month out of my Optima yellow top...never again.
