http://www.buyavette.net/New%20Pictures/120001.jpg
Just in and a heads up on this unbelievable C2 Restomod. A short description will be up this morning with a full description ASAP. This is one of the nicest C2 Restomods we have ever had in our 22 years in business. The resto on this car took seven years to complete and was finished just 6 months ago. The car has 55 miles since completion. :thumbs:
1965 CORVETTE Convertible "RESTOROD": Laser straight RED paint (6 coats red, 2 coats clear professional paint)/ RED leather interior, BLACK Convertible top, WHITE hood Stinger...perfect door/hood body gaps. Ground up restoration as follows:
ENGINE/ TRANSMISSION/ DRIVELINE: NEW CORVETTE Z-06 427 cu in/ 510HP Crate Engine/ dry sump remote oiling/ SpearTech fuel management/ CHROME or POLISHED front engine drive & pulley system by Street & Performance/ underhood STAINLESS BRAIDED fuel, AC, brake lines, oil lines and fittings. NEW Vintage Air Conditioning with polished compressor. WILWOOD master brake cylinder/ Custom exhaust headers/ Stainless ROAD PIPE Side exhausts. NEW TREMEC 6-Speed manual transmission with Overdrive/ NEW Clutch + hydraulic linkage to pedal. NEW 3.73 ratio POSI-TRACTION Differential gears.
CHASSIS: JAMISON Custom tube Space Frame (powder coated bright RED) + C-4 (1996) Suspension. Brake Specialties custom Camber/Toe in rods in rear controls/ CARRERA Chrome Coil Over Shocks, adjustable for ride and height, NEW 13" Disc Brakes all around, calipers powder coated. NEW 25-Gallon CUSTOM ALUMINUM FUEL TANK, Electric fuel pump with STAINLESS BRAIDED LINES/FITTINGS. Anti Sway bars. NEW MICHELIN RADIAL Tires, NEW 2004 Z-06 Chromed Wheels.
UNDER HOOD: NEW DEWITT'S Aluminum H.D. Radiator + Electric Fan & Shroud. NEW Wiper Motor, NEW Headlight Motors, NEW Polished 70 Amp Alternator...All NEW Wiring Harnesses throughout car.
INTERIOR APPOINTMENTS: NEW RED Leather seating, NEW Cut Pile Red carpeting, NEW Door panels/dash pads/dash door, control knobs, dash knobs, door and pull handles, NEW WHITE FACE Gages/ 150 WAT AM-FM radio New Speakers and Electric antenna, NEW Speakers (all new interior parts in cabin). NEW Black Convertible top with powder coated top Frame, all NEW CHROME LATCHES. NEW Windshield, POLISHED Windshield frame and all stainles trim pieces polished beautifully.
1965 Corvette LS7 Restomod Convertible For Sale Stock #1200CJS Red exterior with White stinger, Red leather interior, Black convertible top. 505hp all-aluminum LS7 engine, T56 6 speed manual transmission, 3.73 posi rear-end. Features include air conditioning, power steering, power 4 wheel disc brakes, power antenna, side exhaust, tilt, AM/FM radio. Originally assembled on April 5, 1965, this 1965 Corvette LS7 Convertible really is the best of both worlds, combining classic midyear styling with modern Z06 power and comfort! Built on a Jamison's Custom Corvette tube chassis, this car is so comfortable to drive and handles so well that you will forget it's a '65! This car is just about as fresh as it gets too, showing just 57 miles since its nut and bolt restoration and build. The body on this car has been dressed as a '67, showing a '67 stinger hood, '67 fenders, and a '67 back-up light in the rear. Trim tag shows paint code FF and interior trim code 450B. This car's paint is in very good to excellent condition, showing a gorgeous, deep, show-quality shine. Cloth convertible top is in very good to excellent condition, with a clear window and no rips, tears, or other flaws. Convertible top latches are new, and the stainless steel windshield trim has been polished to a chrome-like finish. Chrome bumpers look to be recent, and are in very good to excellent condition with no patina to speak of. Exterior door handles look recent with no pitting, dulling, or scratches, and the taillights look recent as well with no cracking. Weatherstripping looks to be new, and is super soft and in very good to excellent condition with no dry spots or rotting. This 1965 Corvette LS7 Convertible wears a set of chrome C5 Z06 style wheels, looking to be brand new and in excellent condition with no curb rash or pitting. Tires are premium Michelin Pilot Sport PS2's, looking to be nearly new with an average of 8/32nds tread depth remaining. These tires are sized 245/45/17 on all four corners. The interior of this car shows recent cutpile carpet, leather seat covers, door panels, sill plates, visors, seatbelts, dash knobs, door handles, and dash pads, all in very good to excellent condition. Center console has been slightly modified to accommodate the shifter for the T56 6 speed, and is in very nice shape. A smaller diameter steering wheel with polished spokes and a wood rim has been added, and is in very good condition. Never available from the factory on a midyear, this car also features an aftermarket tilt steering column for easier entry and exit. White faces have been added to the gauges, which are in very good to excellent condition with clear lenses and no fading. Clock is working at this time with a quartz movement. Correct style AM/FM radio is in place and has been upgraded to 150 watts, and the glovebox lid is in very good condition as well. Modern speakers have been added in custom kick panel enclosures. Under the hood of this car sits a brand new 427ci crate LS7 engine that would normally be found in a C6 Z06. This engine features a dry-sump oil system, and billet aluminum pulleys. A mirror has been mounted in the center of the firewall to simulate the ignition shielding that would normally be found on a stock midyear engine, and a Dewitts aluminum radiator and electric fans ensure that this LS7 stays nice and cool. The Jamison tube chassis is powdercoated in Red, and features chrome adjustable Carrera coil-over shocks and C4 brakes, which are fed by a Wilwood master cylinder. A 25 gallon fuel cell has been installed as well, which should provide for excellent cruising range. Other notable new items include headlight motors, wiper motor, polished 70 amp alternator, stainless steel braided pressure hoses, and and all wiring harnesses. A premium Optima Red Top battery provides the starting power for this beast, and a full OBDII diagnostics system is present, complete with a check engine light. This car has been fully serviced, and all instrument gauges, lights, turn signals, brakes, engine, transmission and rear-end are all in good operating condition. Air conditioning blows nice and cold. This 1965 Corvette LS7 Convertible is guaranteed to turn heads and embarrass modern muscle cars at stoplights, call us now before it's gone! FREE 2 YEAR/50K ADDITIONAL MILE WARRANTY WHEN PURCHASED AT ADVERTISED PRICE, GOOD AT ANY REPAIR FACILITY NATIONWIDE!! Our Price: $139,999
More picture here
http://www.buyavette.net/1965%20Corv...%201200CJS.php
