Rear end whine
My 2002 6 spd.with 82000 miles is developing a whine from what seems to be the rear. I get it above 60mph and when the drive system is slightly pulling but not on acceleration or deceleration. Happens in 5th and 6th gear. Put Red Line fluids in tranny and differential about 30.000 miles ago. The whine seems to be getting slightly louder over time. It's not loud - just annoying and new. Ideas?
Originally Posted by Bob Chapman
(Post 1580813700)
Most likely will get louder as well:ack: Mine took around 3k miles to go from a slight hum to downright annoying and not being able to use the radio to cover the noise.
Time for 3.90s from Rick:rock: (see above) |
Does it start off as a low high-pitched frequency sound?
I've notice this on the used 3.42 diff that was just put in. Only under load. |
Most gear whines are on the load (accelerating) side. Usually the noise is gone during coasting or decel. The noise is similar to a straight cut gears in a transmission.
I'm getting a similar whine that starts at 50mph. is the fix just new gears?
Originally Posted by Z28STYLE23
(Post 1580974083)
Both my Trans Am GT and my C5 Anniversary Edition (both with T-56 and 3.42 gears) have whinned at highway speeds. Seems I was told that it was the tranny that was the culprit, but I cannot remember. Mine have not increased in volume ever, so I am just going to live with it.....or turn the stereo up louder. LOL
im having a gear whine also in my 02 z06 , it starts at any speed when im on throttle, if im on the floor with the throttle it goes away, if Im just cruizing I hear it more often.
Yes the ring and pinion are the cause. I swapped a 3.42 diff out of a Z06 into my 99 A4 and found out why they removed it. It whines badly all the time. If you can live with it, it doesn't hurt anything. If not, upgrade time :D
Originally Posted by Rick@RKT56
(Post 1580817929)
Originally Posted by _r2h
(Post 1581624435)
I have a noise that is kind of opposite of this. Most noticeable on cruise, only slightly noticeable on acceleration, completely gone on deceleration. All after it's warmed up and at operating temp. I haven't figured it out yet.
I've had this noise for thousands of miles and it doesn't hurt anything. It's not too bad so I haven't done anything about it. I've got 108k miles and it has never gotten any worse.
My 3.90``s have been whining for over 30,000 miles now, loudest at 50-65 mph. sometimes louder than other times but not getting any worse. last diff change no metal in old oil so I`m living with it. :cheers:
(Post 1580814132)
This is a classic symptom of ring and pinion gears making noise. The noise happens around 65-70 mph in overdrives. If you can't live with it, time for new gears.
Why does this happen? and in my case only or mostly in 6th gear? not enough 'load' on the gears, geez i only have 40,000 mi (2004 year ) and it's been getting worse very annoying like others have said. |
Originally Posted by Rob 99
(Post 1582636798)
Originally Posted by Dennis Wilson
(Post 1581668237)
http://i981.photobucket.com/albums/a...rum/Magnet.jpg |
Wow, sweet example of a magnet's lines of force.
NukeC5
Im not sure that "spirited" driving would be the cause of this. It is a Corvette after all and spirited driving is what the car was made for. I am new to this forum but I have been doing alot of research on the C5 Vettes. A Corvette with 40k miles on it should not have gear noise (unless maybe they ran it dry of lube at LeMans) I think maybe this was a Factory flaw that went unnoticed. |
Originally Posted by Ozzysezit
(Post 1582642137)
NukeC5
Im not sure that "spirited" driving would be the cause of this. It is a Corvette after all and spirited driving is what the car was made for. I am new to this forum but I have been doing alot of research on the C5 Vettes. A Corvette with 40k miles on it should not have gear noise (unless maybe they ran it dry of lube at LeMans) I think maybe this was a Factory flaw that went unnoticed. The Corvette is still a car made from the same parts as any other Chevy V8. Harsh driving will lead to owning a harshly driven car that shows it like any other car. |
