** New Product, C6 Cup Holder Insulator **
*New Product* C6 Cup Holder Insulator
http://i113.photobucket.com/albums/n...22-12-2002.jpg ** This product fits all C6 Models 2005 thru 2013 C6/GS/Z06/ZR1 ** Are you searching for a low cost and easy method to prevent your cold drinks from boiling over? Our C6 Cup Holder Insulator will help keep your cold drinks cold longer? Reduce your cupholder area temperature to a more manageable level by using our easy to install C6 Cup Holder Insulator. Installation is just a matter of pressing the Cup Holder Insulator into place. Laser cut for a perfect fit, 1/4 inch insulation covered in Black Neoprene Rubber for easy cleaning and a clear plastic pull tab for easy removal. Experience a noticeable reduction in temperature with an easy to install and inexpensive alternative. ORDER HERE: http://www.topflightrepro.com/corvet...products.shtml Simple Installation Slide Insulator rubber side up into cup holder area http://i113.photobucket.com/albums/n...4-22-12012.jpg Press down http://i113.photobucket.com/albums/n...4-22-12013.jpg And Done! http://i113.photobucket.com/albums/n...4-22-12015.jpg |
:cheers:
Any special deals on buying both the cup holder insulator and the center console compartment insulator? :cheers:
Originally Posted by CHUXDRM
(Post 1580799482)
I did this 6 years ago. It helps too. It isn't perfect, but it does help.
On 6-19 I ordered the Cup Holder Insulator and the Center Console Insulator. I received them on 6-22 and installed them. Went for a drive today and the difference in temperatures are amazing. The products perform as described. Outstanding products and super fast service. I am very pleased.
Originally Posted by scott53
(Post 1581143227)
Order placed!
Thanks! |
Originally Posted by Blueline
(Post 1581239759)
Order placed!
Thanks! |
Just received mine today with the center console pad also. Great product and super fast shipping!
Thanks again Peter! :cheers: |
(Post 1581292400)
Temperature readings of before and after to show the difference?
Originally Posted by Ferocious C6
(Post 1584305342)
Originally Posted by Top Flight Reproductions
(Post 1584337056)
our testing showed a 20% temp difference :cheers:
I dont want to cool my coffee down :} anyway what is price of that and air hooter induction unit cant see it written anywere and freight to New Zealand thanks
Originally Posted by Mark Wade
(Post 1584751793)
I saw your center console insulator and thought this needed doing... I just ordered a set from you! one suggestion. put the set in a small priority mail flat rate box, save a bit on shipping. thanks though!
Originally Posted by silver_viper_tb
(Post 1589341030)
I just received my order and wanted to say I take back my suggestion. everything arrived packed perfectly ! after driving my car around all day yesterday, the cupholder no longer heats up my cold drinks . It works really well
thanks very much guys |
