Borg Warner T10 4 speed - can you decode this?
http://i789.photobucket.com/albums/y...icture1425.jpg http://i789.photobucket.com/albums/y...icture1426.jpg |
I can't with those pictures. What are the numbers on the parts and what type of casting is it. Cast iron or Aluminum?
T-10 7B case is cast iron . It was used in a lot of GM & Ford products.
There should be a build date to the right of the side cover beginning w. the letter W. Corvettes used this case up to about 11/60 when GM switched to the aluminum case model. |
Originally Posted by Blu72
(Post 1580768779)
http://i789.photobucket.com/albums/y...icture1425.jpg http://i789.photobucket.com/albums/y...icture1426.jpg My book shows: W=Warner Second letter is the month (A-L) Third is the date Fourth is the year (57-63) Last (1 or 2) is the shift (day or night) Hope this helps |
