Cant get timing right on my 78 with MSD 8365 Distributor
So here is my second technical post of the night...And the second time I wrote it thanks to my internet crashing!!! GRRRR!
So I purchased a new GM HEI MSD 8365 Distributor for my 78. I had the stock distributor in it, bought a new intake and decided, I'll throw a new $370 distributor in it too. Luckily since I'm an idiot, I sold the original one on ebay for $30! So, I have nothing to fall back on now. The problem is this...I cant get this thing timed right to save my life. I'm beginning to wonder if I have a defective distributor or whether I just dont have it set up properly. I've talked with some of the local high performance shops in the area, and they have all stated they've gotten defective MSD Distributors new out of the box...so it makes me wonder...? Now I used a timing light and I used the old traditional TDC method with putting my finger over the #1 cylinder until it blew it off while turning the engine over... Here's the problem...I'll have the car running, idle sounds great and no vibration. I'll take the car down the road and higher RPM's create backfiring and the car runs like a$$. So I bring it back and advance the timing. Now the idle runs like a$$ but under higher RPM's, she runs better. I bring it back and try to find a happy median and it just doesnt happen. It either runs good at low RPMs or good at high RPMs, but not both. And these adjustments I'm talking about are miniscule. Like, no more than an inch in rotation. So when I get the timing set at a driveable rate, I tighten the distributor down and park the car. I'll take the car out a week later and it runs like a$$ again? I retard the timing and it begins running "decent"(and I use that term loosely) again. Then, a week later, I'll go to drive it again, and it runs like crap. So this time I advance the timing and it'll run decent again. Everytime I drive it, timing has to be adjusted??? Its like it drives fine one day and then the next, it'll only run on 7 cylinders and the 8th will come in sometimes. Now the distributor is not moving, all plugs and wires are new and have been checked(no arching or meltdowns). I have the AFR 180cc Eliminator heads. As far as the springs in the distributor, I have the factory supplied bright silver springs in it now. I removed the factory installed heavy silver stiff springs and put the loosest ones they provided in it. I have not changed out any of the bearings but dont know if that matters? Has anyone had any trouble out of these or any input as to how to get this PITA to run right? If you can, you'd be my hero! Any ideas/suggestions/etc? I hate to just buy another distributor after spending so much on this one... |
Your initial timing, total timing and total with vacumn need to be correct. This requires the correct vacumn can. springs and limit bushings. No distributor has the correct curve out of the box. Check the timing sticky by BarryK and Lars timing and vacumn can links here.
http://forums.corvetteforum.com/c3-t...long-post.html PS: are you sure you don't have a vacumn or intake gasket leak since the intake change? |
Originally Posted by 63mako
(Post 1580739339)
You should put a non-dial-back timing light on it with a timing tape on the harmonic damper and record what the timing does at 750 rpm, 1000 rpm, 1250 rpm, and so on up to ~3500 rpm. (Ensure that the vacuum advance is disconnected during this effort.) The timing should advance smoothly from about 12 degrees up to about 35 degrees and then hold steady.
If you find that the advance curve did something odd, post what you recorded. There may be an easy solution for this problem, but you'll need to post the test results first. |
Those advance curves they put in there arent exactly accurate.
If you can find someone with a dist machine who can put a nice curve on it for you. Mine was WAY off according to the bushing spec. Are you using a timing light? An inch of dist movement is a HUGE difference in timing. Your AFR heads shouldnt need a ton of total advance btw. If you know of noone Google Bob Jennings Dyno shop , He will get the curve right the first time. |
I agree with the timing tape suggestion. Measure and plot your curve so you know what's going on. It doesn't have to be perfect to run right, just close. Then adjust from there. Heck, you might call the buyer of your original HEI and offer him $45... Good luck, you will get there.
Originally Posted by larrywalk
(Post 1580741538)
If you find that the advance curve did something odd, post what you recorded. There may be an easy solution for this problem, but you'll need to post the test results first. Günther (don´t ask why I know this :toetap:) |
two things cause your issue, loose timing chain, defective control module, if it ran fine with the old dizzy, your chain is fine, call MSD's tech line and have them send you a good one. if it ran fine before the dizzy change and runs like cr$p now, its the dizzy.
(Post 1580741931)
If you can find someone with a dist machine who can put a nice curve on it for you. Mine was WAY off according to the bushing spec. Are you using a timing light? An inch of dist movement is a HUGE difference in timing. Your AFR heads shouldnt need a ton of total advance btw. If you know of noone Google Bob Jennings Dyno shop , He will get the curve right the first time. Oh and on a side note...wanted to let you know Jim got me hooked up on my AFR heads for my 96...matter of fact, they came in yesterday morning! Now just gotta scrounge up the $$$ for all the goodies to go with them! |
(Post 1580741538)
Originally Posted by oldalaskaman
(Post 1580823480)
Send it to Bob.
Getting another one may not help I pulled my hair out with mine These bushings/stops they supply are not accurate unfortunately went through the same thing as you wouldnt time right thought I needed a special light etc. Timing would jump around on the balancer...perfect now My car runs NIGHT and day differently super happy. Youll be glad you did. Hes an old timer who has been doing these for over 40 yrs. If the names Bob Lambeck, Dick Landy Reher Morrison etc ring a bell he was racing right along side them back in the day. Knows his stuff. http://maps.google.com/maps/place?oe...12051697150475 |
(Post 1580823764)
Send it to Bob.
MSD lists the advance curves and stop bushings in the instruction sheet. with a dial back timing light and some time it's not that tough to setup.
A timing tape is kind of cool, but not necessary- with a dial back light and some white paint/nail polish at the "0" mark on the balancer and a dot on the timing tab it's easy to see. |
I think all of you are probably right, it just gripes me to buy something new, and have to 'fix' it, they should work ,out of the box. he could have spent the money he's going to spend fixing that pos on a better product.
