1988 35th radio
Hi there I just put my 88 on the road after sitting around for the past few years and am having problems with the radio. If it sits for a day the radio will turn on and sound for about 10 seconds and then nothing at all. Day later same thing. Any suggestions, would like to keep stock radio in but if need be will go find an after market deck and speakers.
Sure sounds like an internal issue.
If you have a cassette tape see if the player works. In case you decide to keep her stock it will help in repair. Then too it may clear up after some usage of the car. My '88 IROC-Z has the same Bose and it too was intermittent when I first got the car. Over a bit of time it would work longer and now, after a few years, it's flawless. |
Ok thanks, will have to go out and buy a cassette as I have not had one of them for many years now. But worth a try.
Right, then you will know if the base radio has a problem or just the tuner.
BTW, when it craps out does the clock still work or just "darkness"? Also, you might try driving it around with the radio On, even though no sound. Mine would eventually come back on and then play well. |
The clock stays lit up and if you push the buttons you see the radio station for am or fm. Will take it for a ride tomorrow if the rain stops and pick up a tape to try out.
MarkCamp. I too own a 88 35th. I have had the radio rebuilt, in 99, and have rebuilt the Bose amps twice, the last being in 03. They need replacing again. I intend to replace the radio and speakers that are not Bose. You have to access the door speakers, which is not easy for new speaker wiring. Most audio shops that sell new radios can make the conversion for you. Sorry, throw the Bose away. Go the route of a CD or Ipod but keep all the old equipment (in a box). You might need it for resale.
Thanks Had2Hav2, I do believe that is the route I will be taking not sinking money into the old system. From what I have been reading lots of problems with them.
my bose is shot too..
I am thinking about doing this. Mostly because I am cheap. http://www.youtube.com/watch?v=aofga-jT-OU
Originally Posted by HAD2HAV2
(Post 1580618413)
well had2have2, tape did not respond at all so next week new system goes in before the good cruising weather gets here. Picked up a new Sony today with bluetooth and cd and ipod/mp3 along with a nice speaker box that fits in the back perfectly. Will leave factory speakers where they are for future consideration.
Originally Posted by MarkCamp
(Post 1580624165)
well caddy I am going to leave the original speakers where they are and just use the speaker box in the rear of the vehicle. Been along time since I played with auto radios so think I will get someone else to hook it up. Already checked and the one place only charges 35 to installe it so not really worth the swearing and skinned knuckles to do it myself.
TRhanks for the help and offer thou. |
(Post 1580624287)
Well turns out I got brave and installed myself, did not have to run new wires just spliced into old wires and dash kit. So total cost of installation was 22.00 plus the deck. Everything works great looks good and no cuts and bruises.
(Post 1580661107)
1 Attachment(s)
These guys do a great job on rebuilding and refurbishing OEM Corvette stereo equipment. Check them out. :thumbs:
Originally Posted by caddyboy84
(Post 1580664910)
I have a great nugget of advice for you that I really wish I did before I rushed to finish my system. You can actually mount new speakers in those Bose front boxes and bypass those amps, I'm thinking that new modern speakers in those boxes would sound good, but I don't know because I removed the boxes and replaced them with Dyno-mat. If I had it to do over again, I'd try re-using those boxes to see how it sounds. All you have to do is use the + and - wires off the amp to the new speaker, the other two wires power the amp and aren't needed.
Originally Posted by pmihaltian
(Post 1580666065)
(Post 1580666122)
Thanks Caddy will look at that when the warmer weather gets here for now thou just going to be the speakers in the rear box working, are they 4x6 round speakers in front doors?
