How do you remove the timing set crankshaft gear? And install it?
I am putting a new timing set on my new short block, but was wondering how the heck you are supposed to pull the timing set crankshaft gear off without damage? (pic is of my old block) And more importantly, how do I install the new one without damage to my new crank and new timing gear?
http://forums.corvetteforum.com/pict...ctureid=108962 |
OK. I have no idea how this posted in C5 tech. Moderators please move to C6 TECH.
This is a C6 Z06 LS7.
3 Attachment(s)
Likely same tools as used for LS1
Removal tools Attachment 48186714 Removal Attachment 48186715 Installation Attachment 48186716 |
Nice. Where did you purchase these tools?
fleabay, they are the Kent-Moore factory tools.
Originally Posted by vettenuts
(Post 1580585744)
I made one with a piece of 1/8" steel, a hole saw, and a drill and tap.
Doesn't look pretty like that, but worked fine. You can use your old part to tap on the new one. Ron |
Originally Posted by RonSSNova
(Post 1580586692)
(Post 1580586692)
Doesn't look pretty like that, but worked fine. You can use your old part to tap on the new one. Ron But I am having trouble finding these tools on ebay... |
I used a three jawed puller to remove. Then made my own installation tool out of threaded rod stock with a nut welded on the end. Then I use an old bearing race and nut to do the actual pressing into place.
