Correct starter?
l'm trying to determine if my old starter is correct for my car. I just replaced it with a parts store rebuild and don't want to return it for the core charge if its original.
It is marked as follows..1108430 4D191. The nose of the starter is marked with the digits 881. The car is a 71 with a May build. Thanks in advance, Bob |
Originally Posted by Roadster71
(Post 1580530762)
John,
What would the p/n be for a 4 speed car? In what way are the starters different? The car is a standard shift. Thanks, Bob |
(Post 1580540278)
John,
Originally Posted by JohnZ
(Post 1580548000)
Early '71 small-block 4-speed cars used 1108338, later 71's used 1108418. The 4-speed cars used a 14" 168-tooth flywheel, and the automatics used a 12-3/4" 153-tooth flexplate; the starter noses are different between the 4-speeds and automatics due to the different ring gear diameters. :thumbs:
Thanks |
(Post 1580548282)
So it appears what I have is a rebuilt starter body for a auto with a nose for a 4 speed. A mismatch of parts that would make no difference to a rebuilder.
Thanks |
starter date code
I have a spare starter that was given to me for my 1969 427 with 4 speed manual. The numbers are 1108776 6M164 What is the year of the starter? Thanks, Bob
Originally Posted by rep69
(Post 1582128057)
Thanks for the information. Interesting that is was made for a small block automatic and my car is a big block manual. Someone made a mistake years ago. I guess it can be used for a core exchange,or I could sell it. Bob
