350 cam questions
Hi, New to this board, maybe this question has been asked before, but I need some help in deciding whether to use a Summit 1103 cam
(214/224 duration at .050, with .442/.465 lift, intake closes at 34 ABDC, lobe centers of 107/117. Engine is a 350, bored .030 over with 9.1 to 1 compression, patriot vortec heads with 64 cc chambers, flat top pistons, and felpro 1094 head gasket coupled to a TH350 with 3.07 rear gears and stock converter I am thinking of using the summit cam and installing it at 4 degrees advanced instead of straight up to gain some bottom end torque, or using the tried and true 929 cam straight up. I've used the Summit 1102 in a previous build, which worked very well....is the 1103 too much? thanks |
Originally Posted by blacknwhitedog
(Post 1580457551)
Given the trans and gears, I would look more towards one of the CompCams "4x4" cams with additional advance ground-in.
The Summit (Elgin) cams are an "old skool" lobe design and will make less power than a comperable more agressive lobe profile. |
Sounds like a nice cam for your combination. I would install it straight up as well.
I usually don't comment on cams. But your higher compression especially if you are using only two valve relief flat tops require more cam to stay out of detonation. I would advise the next larger the 1104. Just for reference the stock L-82 cam was 222/222 with I think 114 lobe centers and it was a very mild cam
Anybody that tell you to buy a Comp Cams cheap pot metal cam is not your friend. Untold numbers of flattened lobes even with the best oils. I'm one of the victims:toetap: |
Originally Posted by gkull
(Post 1580458679)
Originally Posted by 63mako
(Post 1580457934)
I would intall the 1103 straight up. About right for a 9 to 1 build. That said flat top piston, 64 cc chambers and 1094 gasket is generally closer to 10 to 1.
Thanks, I'm going to re check the pistons and verify the CR. I purchased the engine kit from PAW over a year ago, and the tech told me they were going to produce around 9:1, but yeah, I had always thought that flat tops were closer to 10:1 as you stated. I'm going to recheck the valve reliefs and deck height....I like 10:1 better. |
(Post 1580458679)
This will help you figure out your desired intake closing point to optimize DCR on any cam. You can use the DCR calculators online and plug in your actual intake closing point then. http://forums.corvetteforum.com/c3-t...lculation.html |
Don't listen to anyones opinion on what your compression ratio is, calculate it yourself. Also the vortec heads will take less spark advance than you may be accustomed to, start out very conservative. If your budget can stand it go with a hydraulic roller, you'll be glad you did later.
(Post 1580457551)
(214/224 duration at .050, with .442/.465 lift, intake closes at 34 ABDC, lobe centers of 107/117. Engine is a 350, bored .030 over with 9.1 to 1 compression, patriot vortec heads with 64 cc chambers, flat top pistons, and felpro 1094 head gasket coupled to a TH350 with 3.07 rear gears and stock converter I am thinking of using the summit cam and installing it at 4 degrees advanced instead of straight up to gain some bottom end torque, or using the tried and true 929 cam straight up. I've used the Summit 1102 in a previous build, which worked very well....is the 1103 too much? thanks Keep the shiny side up!:rock: Scott |
