1968 corvette 327 l79
hi was wondering if someone could show me a photo of the the crank case vent on the 327 l79 motor i dont know what to look for
the valve covers can be changed and the manifold can be changed but the sure way to know a 327 is that crank case vent thanks Rod:canadaflag: |
Sorry, mine does not have the stock covers or manifold, and my spare engine and the original are disassembled. :confused2:
If I remember correctly, the SB '68 had a breather tube sticking up from the front of the intake manifold area with a breather cap on it. That was the only C3 year to have that design.
Originally Posted by 7T1vette
(Post 1580377432)
I believe 7T1 is correct
Here's what you're looking for. The tube at the front mentioned above serves as the oil filler tube and the inlet for the PCV system I believe.
http://www.fossilcars.com/chevrolet-...-intake/175016 http://www.fossilcars.com/images/201...75016-0-lg.jpg |
The tube in the front is only for oil fill, on the 327's only. Older C-2's had a tube on the side of the oil fill tube for the pcv hose. The original 68 L-79 only chrome valve covers each had one hole in them. The left hand side was for the pcv valve and hose and the right hand side was for a metal tube and hose up to the air cleaner base spark arrester.
My recollection was incorrect. That tube is just for oil fill and had a sealed fill cap on it. Thanks for the correction.
[I'm told that "memory" is the second thing to go, as we grow older; but, I can't remember the first... :confused:] |
For the 68 327s, the PCV valve is in the left valve cover and connects by hose to the base of the carburetor. AIM shows it. 68 327s have no road draft tube like earlier small blocks had.
:thumbs: |
hey you guys have all been great 7t1 vette youre hillarious!!! but Tom Falconer collectors guide says page 18 "valve covers and intake manifolds could be changed but there is no question about that rear block vent" so my question to you friendly fellas is where is it??
and what is it ?? he calls it a crank case vent at the back of the block just beside the distributer thanks Rod |
Someone with a copy of the '68 AIM would have to assist on this one, I think.
(Post 1580386041)
...Someone with a copy of the '68 AIM would have to assist on this one, I think...
I re-read that section in Mr. Falconer's book and I am wondering whether he might be mistaken. The plug looks like a small freeze plug. I have seen them, but only on older small blocks. It is on the pad on the block to the left of the distributor and very close to the oil pressure line fitting if it is there. If memory serves, my original 327/300 assembled in April, 1968 does not have the plug. :thumbs: |
(Post 1580386927)
[IMG]
I re-read that section in Mr. Falconer's book and I am wondering whether he might be mistaken. The plug looks like a small freeze plug. I have seen them, but only on older small blocks. It is on the pad on the block to the left of the distributor and very close to the oil pressure line fitting if it is there. If memory serves, my original 327/300 assembled in April, 1968 does not have the plug. :thumbs: http://i45.photobucket.com/albums/f6...dDraftTube.jpg In earlier years (pre-PCV) a road draft tube was installed as crude method of venting crankcase vapours. That's what caused the filthy black strip down the center of many 50s and 60s highways. |
thanks for the info guys as i became a little nervous after reading Mr Falconers guide but with all due respect to him i took it as bible perfect and no one is perfect... so with that in mind i thought maybe i coudlve had a fake 327 even though the block #s match the vin in the window if you guys go to my profile you can see a pic of my motor
kind regards and many thanks Rod |
http://i988.photobucket.com/albums/a...e/SDC10036.jpg
http://i988.photobucket.com/albums/a...e/SDC10032.jpg http://i988.photobucket.com/albums/a...e/SDC10122.jpg ...three pics from the very original 42,000mi Silver '68 L-79 4spd car I used to own.:yesnod: |
thanks Paul looks the same as mine minus ignition shielding ...take a peek at my motor on my pics if you get a chance let me know your thoughts....:)
Originally Posted by reel vinyl
(Post 1580387402)
sure id be happy to do that its getting some minor mechanical right now though...would the vin # help for now???? i can submit the casting #s wednesday or thursday...i know also it has an HT on the block as well
(Post 1580387457)
thanks Paul ......whats smog set up?
