2nd versus 3rd gear-advice needed
Candidly, gearing is a giant unknown to me. Purchased the car four months ago and have no idea about any mods made to tranny or diff. Tranny # match and differential appears to be original.
Shifting from 2nd to 3rd gear offers little difference (IMO) in speed, RPMs seem to climb to quickly without a significant change. Wondered if this is a transmission issue, a rear differential issue, or can be worked with at either end. I will read up on the topic-can someone direct me to a resource? Thanks. |
Try servicing the transmission.
Originally Posted by bhk2
(Post 1580367680)
Shifting from 2nd to 3rd gear offers little difference (IMO) in speed, RPMs seem to climb to quickly without a significant change. Wondered if this is a transmission issue, a rear differential issue, or can be worked with at either end. I will read up on the topic-can someone direct me to a resource? Thanks. The only difference between driving with the gear selector in "2" vs. "3" is that the transmission will only upshift to 2nd-gear when in "2", while in "3" it will upshift to 3rd-gear, which is the top-gear in the automatic. Up until the point where the transmission would shift to 3rd-gear, there will be no difference in driving. If the engine is not upshifting to top-gear when you have the selector in "3", then the governor may be sticking or there may be a problem in the valve-body. |
Or your shift linkage needs adjustment/repair. Assuming you have an automatic. Cheaper than any trans work.
As the previous poster said, when you select "2" on a Turbohydramatic, the trans starts in first, and will shift normally into second. It just won't go into high gear. Around town, you won't see an enormous difference in RPM. On the highway, though, it will be significant. |
I should have specified that it is a manual transmission, an M-20. The car shifts fine, but I can shift from 1st to 3rd without the need to visit 2nd.
Probably a close ratio M-21 tranny would be my guess
Originally Posted by Phil Zell
(Post 1580375972)
(Post 1580375920)
(Post 1580367680)
Shifting from 2nd to 3rd gear offers little difference (IMO) in speed, RPMs seem to climb to quickly without a significant change. |
