1996 power steering pulley
Ok I have seen tons of post on this subject and I have spent alot of time checking places....I need a power steering pulley for a 1996 lt1 Corvette . I have tried several places listed in the post,but everyone says they are no longer available,spent a half hour on phone with speed inc.today and they could not find one either.any help would be great thanks
Help
Anybody out there help!!!!!!!!!!!!
found mine on ebay. good luck
The link below allows you to search across multiple salvage yards for parts by distance from your location.
http://www.mypartshop.com/ I saw a few hits on pumps from your model year. Give one of them a call and see if they will just sell you the pulley or if not sell you a pump with the pulley. |
thanks
thanks for the info i will check it out...
That would be smooth sided steel pulley, yeah, good luck. No one makes them anymore. All that is available is Ebay, swap meets, salvage yards. I got one last year from a Corvette Salvage yard.
Ironically, they make the 92-E93 plastic ones. $400 a pop. :willy: Why do you need one? |
Mine has a really bad wobble in it and I have been through 2 altenators ...had it checked by GM dealer and they say the wobble is causing problem with alternator bearings
Originally Posted by mike88amped
(Post 1580344212)
Originally Posted by Muffin
(Post 1580345908)
No question about needing a straight pulley but I wonder about causing alternator bearings to fail. Idle thought: can a pulley be straightened?
I would check your idlers and tensioner as well for good bearings/no play,etc...Check pulley alignment with a straight edge, specs. are in FSM. What I want to know is how does a steel pulley get bent? |
Well mines bent as well and looking for a replacement
(Post 1580335612)
http://www.ebay.com/itm/KASTAR-Maste...item257a47bc5c |
A bent pulley would indicate either an incorrect removal proceedure OR a failed attempt at an install when replaceing a pump. The only other possible explanation is that presently it's not a pulley problem but the shaft or front bearing in the pump has failed or is failing. Just sayin'
I sent you a pm of a guy that parts out c4s. He will have your part
1 Attachment(s)
(Post 1580335612)
http://www.harborfreight.com/pulley-...set-40749.html |
I have a complete pump, rebuilt by turn one for sale cheap.
