Tomorrow testdrive C6 2005 manual... things to look out for?
Hello corvette owners :) :flag:
Tomorrow I'm going to look at a corvette c6 from 2005 with 30.000 miles on the clock :) The car is MANUAL shifted. Are there common things to watch out for when I do the testdrive? I also read some things about the gearbox that it's a weak thing with the 2005 models.. I hope someone can post some things to check when I do my testdrive tommorow! This is the car: http://img820.imageshack.us/img820/9784/70719473.jpg Thanks! |
ask about the roof on the 2005
Hey,
My 2005 coupe is great and I have 61,000 miles. Biggest deal was the roof panal seperation. Mine flew off because the glue was bad. GM made it rite and I was pleased. I go to the GLEN and race mine for 2 days each spring and I don't have a problem withe 6 speed. I hope you find a great car ! Barry |
If you're a serious drag racer doing high RPM drops off-the-line you'd probably want to beef-up the drive line/differential but I don't consider the 2005 transmission weak per se. I run road courses in my modified 2005. I put-down 490 RWHP. I rarely do high RPM launches off-the-line but otherwise I'm often running WOT and making high RPM up-shifts and downshifts. Despite hard track use my 2005 OEM transmission has held-up fine.
The only thing to look out for is You're Gonna Love It. :thumbs: :cheers: :flag:
From the 2005 owner's manual.
One to Four Shift Light (Manual Transmission) When this light comes on, you can only shift from FIRST (1) to FOURTH (4) instead of FIRST (1) to SECOND (2). You must complete the shift into FOURTH (4) to turn off this feature. This helps you get the best possible fuel economy. After shifting to FOURTH (4), you may downshift to a lower gear if you prefer. Notice: Forcing the shift lever into any gear except FOURTH (4) when the 1 TO 4 SHIFT light comes on may damage the transmission. Shift only from FIRST (1) to FOURTH (4) when the light comes on. This light will come on when: • The engine coolant temperature is higher than 169°F (76°C), • you are going 15 to 19 mph (24 to 31 km/h) and • you are 21 percent throttle or less. |
Some are minor, obviously, but some like parasitic drain, erratic fuel gauge and loose harmonic balancer could be very very bad.
2005 Chevrolet Corvette V8-6.0L VIN U Recall and Technical Service Bulletin Titles TSB Number & Issue Date TSB Title 09230B MAY 10 Recall - Roof Panel Separation 10118 APR 10 Recall - Service Active Handling System Message 06041C MAY 07 Recall - Body Color Roof Adhesive Separation 05086A NOV 05 Recall - Power Steering Hose Fractures 04086 JAN 05 Recall - Rear Brake Line Routing TSB Number & Issue Date TSB Title 08089C NOV 08 Campaign - Deactivation Of Analog OnStar(R) 07301 AUG 08 Campaign - Fuel Tank Filler Cap Warranty Extension 05112D JUN 06 Campaign - Potential Painted Roof Separation 04096A JAN 05 Campaign - Incorrect Air bag OFF Indicator (Canada) TSB Number & Issue Date TSB Title 00-03-10-002F APR 11 Wheels - Chrome Wheel Staining/Pitting/Corrosion 03-08-48-006H APR 11 A/C - Window Defroster Contact/Tab Repair Information 04-07-30-037E APR 11 A/T - Dexron®(R)-VI Fluid Information 08-08-67-013F MAR 11 Body - Various Noises from Lift Off Roof While Driving 06-00-89-031B MAR 11 Engine, A/T - Identification Information 10-08-50-003A MAR 11 Restraints - Driver/Passenger Seat Head Rest Information 99-08-51-007E MAR 11 Wheels/Tires - Refinishing Aluminum Wheels 11-00-90-001 MAR 11 Engine - GM dexos 1 and dexos 2(R) Oil Specifications 02-07-30-052G MAR 11 A/T - Fluid Oil Cooler Flush 99-08-51-001B MAR 11 Body - Paint-Less Dent Repair Recommendations 06-08-43-003C FEB 11 Glass/Body - Windshield Wiper Performance 09-09-40-001A FEB 11 Restraints - Seat Belt Warning Lamp On/Buckling Issues 01-08-42-001H JAN 11 Lighting - Exterior Lamp Condensation and Replacement 05-08-46-004C DEC 10 OnStar(R) - Number Incorrect/Incorrectly Assigned 06-08-50-009F DEC 10 Restraints - Passenger Presence System Information 03-07-29-004G DEC 10 Manual Transmission - M/T Operating Characteristics 05-03-07-009C DEC 10 Steering/Suspension - Wheel Alignment Specifications 09-06-03-004D DEC 10 Electrical - MIL ON/DTC's Set By Various Control Modules 07-08-49-020D DEC 10 Instruments - IPC Odometer Programming Reference Guide 01-08-51-003B NOV 10 Body - Application of Anti-Corrosion Materials 04-06-04-054B NOV 10 Engine Controls - Aftermarket Accessory Usage 08-07-30-035B NOV 10 A/T - Water Or Coolant Contamination Information 10-08-62-002 NOV 10 Body/Frame - Front License Plate Bracket Installation 08-08-67-001A OCT 10 Body - Cracks in Transparent Removable Roof Panel 05-06-04-022G OCT 10 Fuel System - TOP TIER Detergent Gasoline (Canada) 10-08-45-001B OCT 10 Electrical - Information For Electrical Ground Repair 05-09-40-002E OCT 10 Restraint System - Normal Safety Belt Locking Conditions 10-08-44-006 OCT 10 Navigation - Report Missing/Inaccurate Nav. Map Info 10-08-52-004 OCT 10 Keyless Entry - No Remote Detected/No Fobs Detected 00-08-48-005D SEP 10 Body - Vehicle Glass Distortion Information 04-08-50-006D SEP 10 Interior - Seat Cover Wrinkle/Crease/Burn Info 10-08-98-002 AUG 10 Body - Drilling High Strength Steel Using CryoCobalt(R) 05-06-01-034L JUL 10 Engine - Oil Leaks From Rear Cover 07-07-31-001C JUL 10 Clutch Hydraulic System 10-03-16-001 JUL 10 TPMS System - Service And Re-Learning Sensor IDs 03-00-89-008E JUL 10 Body - Metal Body Panel Corrosion Protection 06-08-51-005A JUN 10 Body - Hem Flange Sealer For Corrosion Protection 03-08-98-002B JUN 10 Body - Squeeze Type Resistance Spot Welding/Equipment 07-06-04-019D JUN 10 Electrical - Intermittent MIL/DTC P2138/Reduced Power 99-09-40-005F JUN 10 Restraints - Extender Availability For Seat Belt 02-08-42-001D JUN 10 Lighting - Headlamp Polycarbonate Lens Damage Prevention 08-08-110-001E JUN 10 Interior - Convertible Headliner Frayed At Outer Edges 06-03-10-010A JUN 10 Wheels - Changing Procedures/Precautions 10-00-89-010 MAY 10 Locks - Key Code Security Rules and Information 00-03-10-006F MAY 10 Wheels/Tires - Tire Radial Force Variation (RFV) 04-06-01-029E APR 10 Vehicle - Engine Crankcase and Subsystems Flushing Info. 05-03-10-003F APR 10 Tires/Wheels - Low Tire/Leaking Cast Aluminum Wheels 04-03-10-001F APR 10 Tires/Wheels - Tire Puncture Repair Procedures 08-03-10-006C APR 10 Tires/Wheels - Tire Slowly Goes Flat/Warning Light ON 05-03-10-020C APR 10 Wheels/Tires - Use of Nitrogen Gas in Tires 06-08-44-012E APR 10 Navigation System - Software/DVD Update Program 07-04-20-002B APR 10 Drivetrain - Vibration/Noise While Making A Turn/Accel 10-08-110-001 MAR 10 Interior - Proper Use of Floor Mats 09-08-67-013A MAR 10 Body - Various Folding Top Issues 08-08-64-011A FEB 10 Mirrors - Heated Mirrors, Defrosting Time 00-07-30-009D FEB 10 A/T - Goodwrench® Transmission Replacement 01-07-30-042F FEB 10 A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise 00-06-01-026C FEB 10 Engine - Intake Manifold Inspection/Replacement 09-03-10-017 DEC 09 Wheels/Tires - Replacement Wheel Weight Information 99-04-20-002F NOV 09 Drivetrain - Clunk Noise Shifting From PARK Into Gear 06-08-64-001B OCT 09 Body - Side Window Chipping Information 05-03-08-002C OCT 09 Suspension - Shock Absorber/Strut Leakage Information 06-08-111-004B SEP 09 06-08-111-004B - BULLETIN CANCELLATION NOTIFICATION 09-08-48-006 SEP 09 Body - Stain/Film On Windshield Glass Perimeter 04-06-04-047I AUG 09 Fuel System - 'TOP TIER' Detergent Gasoline Information 06-02-32-013B AUG 09 Steering - Power Steering Pump Replacement Tips 03-03-10-007E AUG 09 Wheels/Tires - OE Tire/Wheel Characteristics 07-06-04-022G JUL 09 Fuel System -07-06-04-022G End Of Need For Information 99-08-64-016C JUL 09 Body - Maintaining Exterior Weatherstrip Appearance 08-06-01-008A JUL 09 Engine - Drive Belt Misalignment Diagnostics 07-06-01-016B JUL 09 Engine - Noise/Damage Oil Filter Application Importance 08-03-10-004A JUL 09 Wheels/Tires - Accessory Wheel & Tire Information 07-07-31-001B JUL 09 M/T - Clutch Hydraulic System Service Information 05-08-51-008C JUN 09 Body - Bumps or Rust Colored Spots in Paint 07-07-30-010B JUN 09 A/T Controls - Snapshot Data Upload Information 08-08-42-005B JUN 09 Lighting - Headlamp Warranty Replacement Guideline 99-01-39-004C JUN 09 A/C - Musty Odors Emitted From (HVAC) System 08-08-42-005B JUN 09 Lighting - Headlamp Replacement Information 07-09-40-002A JUN 09 Restraints - Seat Belt Latch Stop Button Availability 06-08-44-015B MAY 09 Audio System - Noise When Using Portable Playback Unit 02-08-44-007D MAY 09 OnStar(R) - Negative Impact of Cloth/Vinyl Roofs 03-06-04-030G APR 09 Fuel System - Driveability Issues/MIL/Multiple DTC's 09-08-46-001 APR 09 OnStar(R) - Generation 6 Service Procedures 08-03-10-005A MAR 09 Wheels/Tires - Chrome/Steel Valve Stem Cap Precautions 00-05-22-002L MAR 09 Brakes- Disc Brake Warranty Service And Procedures 09-08-48-002A MAR 09 Body - Marks/Stains on Windshield When Wet 08-08-44-010F MAR 09 Navigation Radio - Diagnostic Tips 02-08-98-002C FEB 09 Body - Hem Flange Rust Repair Information 01-07-30-036H JAN 09 A/T Control - DTC P0756 Diagnostic Tips 07-08-98-001A JAN 09 Body - Non-Approval of Clipping For Collision Repair 00-00-90-002J JAN 09 Tires - Correct Inflation Pressure Information 09-07-31-001 JAN 09 M/T - Low Clutch Pedal/Difficult Shifting 07-08-64-022B JAN 09 Instruments - Unnecessary Park Assist Mirror Replacement 01-06-01-011E DEC 08 Gasoline Engine - Oil Consumption Guidelines 05-03-10-015B DEC 08 Wheels/Tires - Tire Rotation Information 04-07-30-017B NOV 08 A/T - Revised Converter Check Valve/Cooler Line Fitting 08-06-03-009A OCT 08 Electrical - Reducing Intermittent Electrical Concerns 05-08-46-006Q OCT 08 OnStar(R) - Analog/Digital Ready System Digital Upgrade 01-07-30-032E SEP 08 A/T - 4T65E Fluid Leaking From A/T Vent 00-00-89-027E SEP 08 Interior - Elimination Of Unwanted Odors 08-08-46-006 SEP 08 Audio System - XM(R) Terrestrial Repeater Changes 06-08-46-008C SEP 08 OnStar(R) - Analog/Digital System Information 05-03-10-005D SEP 08 Wheels/Tires - Upsized Wheel/Tire Characteristics 08-08-49-011B SEP 08 Instruments - Speedometer Accuracy Information 08-08-44-028 AUG 08 Audio - Inadvertent Steering Wheel Button Activation 08-08-64-012 AUG 08 Interior - Door Speaker Rattle, Buzz, Squeak 08-08-46-004 AUG 08 OnStar(R) - Aftermarket Device Interference Information 08-08-44-026 AUG 08 Audio System - Refurbishing Radio Faceplates/Knobs 02-06-03-008D JUL 08 Charging System - Low Voltage Display/Battery Discharged 05-06-02-001A JUL 08 Cooling System, A/C - Aluminum Heater Cores/Radiators 08-08-44-023 JUN 08 Navigation Radio - Adaptation After Radio/Battery R&R 05-00-89-072B JUN 08 Engine/Fuel System - Oil/Fuel Additive Information 00-07-30-022D JUN 08 A/T - 4L60/65E, No Reverse/2nd or 4th Gear 08-08-67-009 JUN 08 Body - Convertible Top Stowage Compartment Bracket Rust 08-04-20-003 JUN 08 Drivetrain - Axle Nuts Appear to be Loose 08-07-30-027 JUN 08 A/T - No Movement in Drive or 3rd Gear 06-08-67-002A JUN 08 Body/Interior - Hard Top Squeaks When Stowed in Trunk 08-07-30-008B JUN 08 A/T - Diagnostic Information for DTC's P0894/P1870 05-05-23-007A MAY 08 Brakes - Brake Rotor Visual Crack Information 07-04-95-001A MAY 08 Drivetrain - Rear Wheel Tapping/Scraping Noise 05-08-68-001B MAY 08 M/T - MIL ON/DTC P0833/Cruise Control Inoperative 08-07-30-026 MAY 08 A/T - Slight Vehicle Movement In Park At Start Up 08-08-110-010 MAY 08 Interior - Floor Mat and/or Trunk Partition Comes Loose 08-03-10-007 MAY 08 Tires - Minimizing Damage to TPM Sensors 01-07-30-010C MAY 08 A/T - Torque Converter Replacement Information 08-03-16-003 MAY 08 Tire Monitor System - TPM Sensor Information 04-06-04-036E MAY 08 Emission - Emissions Programming Warranty Coverage 03-07-30-007E MAY 08 A/T - Gear Engagement Time Information 08-07-30-009B MAY 08 A/T - 4T80E, Slips in Gear/L/H Axle Seal Leaks 05-06-03-002C APR 08 Battery/Charging System - Electrical Diagnostics Info. 02-06-03-009C APR 08 Electrical - Battery Charging Tips/Recommendations 00-06-01-012C APR 08 Engine - Use of 'Surface Conditioning Disks' 08-08-47-001 MAR 08 Keyless Access System - Information/Operation 08-08-51-002 MAR 08 Body - TPO Fascia Cleaning Prior to Painting 08-08-52-002 FEB 08 Remote Starting System - System Inoperative Diagnostics 08-09-41-003 FEB 08 Restraints - Usage of Used/Salvaged/Imitation Components 05-00-89-078B FEB 08 Fuel System - GM Fuel System Treatment PLUS(R) Info. 06-06-04-035A FEB 08 Fuel System - E85 Fuel Usage Precaution 06-06-01-010A FEB 08 Exhaust System - Catalytic Converter Precautions 04-03-10-012B FEB 08 Wheels - Chrome Wheel Brake Dust Accumulation/Pitting 01-05-23-001B JAN 08 Brakes - Rotor Lateral Runout Correction Information 99-08-52-005C JAN 08 Keyless Entry System - Characteristics of Operation 08-01-38-001 JAN 08 A/C - Refrigerant Recovery/Recycling/Equipment 05-06-02-002B JAN 08 Cooling System - DEX-COOL®(R) Coolant Leak Detection Dye 00-08-46-004C JAN 08 OnStar(R) - Re-establishing OnStar(R) Communications 02-08-46-006C JAN 08 OnStar(R) - Incorrect GPS Position Reported During Call 07-00-89-060 DEC 07 Electrical - GM-Approved Terminal Probe Test Kit 02-08-46-007C NOV 07 OnStar(R) - Loss of GPS Signal/Hands Free Issues 06-02-35-002B OCT 07 Electrical - Service Active handling Message/DTC C0710 05-06-01-010B SEP 07 Engine - Sealant Usage/Procedures 07-08-45-002 SEP 07 Electrical - Aftermarket Fuse Warning 07-08-67-006 AUG 07 Body - Convertible Top Won't Close Properly/Crooked/Bent 03-06-03-001D AUG 07 Starting System - Starter Cranks After Key Released 05-06-04-035C JUL 07 Fuel System - E85 Fuel Usage Precautions 05-08-44-005A JUL 07 Entertainment System - Headphone Foam Pad Replacement 05-08-59-003E MAY 07 Body - Popping/Clicking Noise From Roof Near Windshield 07-08-64-011 MAY 07 Windows - Do Not Lower Properly/Indexing Problem 07-07-30-008 MAY 07 A/T - 4L60-E/4L65-E/4L70-E Production Update 07-08-63-001 APR 07 Body - Polypropylene Energy Absorber Replacement 07-08-44-007 APR 07 Navigation System - Replacement Navigation Discs 06-02-32-012B APR 07 Power Steering - Shudder/Vibration at idle 02-08-42-004A MAR 07 Instruments - Reduced PRNDL Display Visibility 07-06-03-001B MAR 07 Electrical - Dead Battery After Extended Storage 07-06-01-002 MAR 07 Engine - Revised Connecting Rod Bolt Torque 04-08-44-024A FEB 07 Computers - Radio Fuse Removal Prior to Programming 04-07-30-013B FEB 07 Engine, A/T - Shift/Driveability Concerns/MIL ON 05-07-30-018A JAN 07 A/T - Cold Weather Shift Characteristics 06-08-64-008A DEC 06 Body - Window Glass Re-Initialization procedure 06-05-22-007 NOV 06 Brakes - Rotor/Drum Refinishing Labor Operations 06-00-89-054 NOV 06 Warranty - Claims Submission 06-00-89-050 NOV 06 Warranty - DTC's Required On Repair Orders 06-08-67-006A NOV 06 TSB 06-08-67-006 CANCELLATION NOTIFICATION 01-07-31-002B NOV 06 M/T - Hydraulic Clutch Bleeding Procedure Improvement 06-08-49-020 OCT 06 Instruments - Heads Up Display Bezel Warped 00-06-04-033B OCT 06 Emissions - OBDII I/M Readiness Testing 02-08-98-001C OCT 06 Body - Metal Panel Adhesive Bonding Information 01-07-30-038D SEP 06 A/T - Poor Performance/MIL ON/DTC P0757 06-07-30-017A AUG 06 A/T - 4L60-E/4L65-E/4L70-E Whine/Whistle/Chirp Noise 00-06-02-006D AUG 06 Cooling System - Coolant Recycling Information 06-06-04-037 AUG 06 Engine Controls - MIL Function During I/M Testing 06-01-39-007 JUL 06 A/C - Contaminated R134A Refrigerant 06-08-110-005 JUL 06 Interior - Floor Mat Retainers Loose/Separating 03-07-30-043A MAY 06 A/T - Shift Lock Control Feature Function 05-08-44-014B MAY 06 Audio System - Poor/No Radio Reception/Static 06-06-04-030 MAY 06 Fuel System - E85 Refueling Station Information 03-04-20-006A MAY 06 Drivetrain - Rear Differential Fluid Leaks 05-07-30-028A MAY 06 A/T - 4L60-E/4L65-E/4L70-E Product Updates 06-08-45-004 MAY 06 Electrical - Instrument Panel & General Wiring Repair 06-08-67-004 APR 06 Body - Power Folding Top Tonneau Inoperative 06-08-64-019 APR 06 Paint - Scuffing/Dulling Dirt Impingement on 1/4 Panel 05-08-64-002B APR 06 Body - Door Latches Freezes in Extreme Cold 02-08-48-001B MAR 06 Body - Urethane Adhesives for Glass Applications 02-06-04-015A MAR 06 Starting System - Engine No Start/No Crank Condition 02-08-46-010G MAR 06 OnStar(R) - Programming for Canadian French 06-03-10-004 MAR 06 Tires/Wheels - Wheel Weight Usage Precautions 05-06-01-001D FEB 06 Engine - Check Gauges Lamp ON/Low Battery 02-06-05-004B FEB 06 Accessories - DTC's P0300, P1380, P1381 05-08-44-029A FEB 06 Audio System - Radio Knob Availability 06-08-49-004 FEB 06 Interior - Revised Console Trim Panel Replacement 04-08-46-002B FEB 06 OnStar(R) - Unable to Connect, Bulletin Cancellation 06-06-04-007 FEB 06 Electrical - DTC P0606/P0689/P1516/P1682/P2176 04-06-04-051B JAN 06 Fuel System - Fuel Injector Maintenance Cleaning 05-09-41-010 DEC 05 SRS - New SIR System Disabling Procedure 05-08-50-003A DEC 05 Interior/A/C - Heated Seats Inop. One Week After Repair 05-03-10-019 DEC 05 Tires - Run Flat/Zero Pressure Tire Info./Service 05-08-49-027 NOV 05 Engine Controls - Erratic Fuel Gauge Readings/DTC's Set 02-01-39-004B NOV 05 A/C - New PAG Oil 05-06-04-041A NOV 05 Instruments - Erratic Fuel gauge Readings/DTC P0463 Set 05-04-95-001 NOV 05 Drivetrain - Rear Axle Nut Torquing Procedure 01-07-30-030B OCT 05 A/T - 4L60-E/4L65-E Harsh 1-2 Upshift Diagnosis 05-08-42-015 OCT 05 Lighting - Headlamp Ballast Identification 01-07-30-041B OCT 05 A/T - Diagnosing Fluid Leaks 01-07-30-002E SEP 05 Electrical - A/T Stuck in 2nd/3rd Gear/MIL ON/DTC's 05-06-04-060 SEP 05 Engine, A/T Controls - Shared Diagnostic Trouble Codes 02-07-30-024B AUG 05 A/T - Cracked Case Diagnosis 05-07-31-001A AUG 05 M/T - Clutch Pedal Won't Go to Up Position at High RPM 03-06-04-012A AUG 05 Electrical - Harness Connection Inspection 05-08-67-009 AUG 05 Body - False DTC B3666 With No Power Top Issues 05-09-40-003 AUG 05 Restraints - Passenger Seat Belt Buckle Hard to Move 05-06-03-005 JUL 05 Electrical - Revised Negative Battery Cable Service 05-08-67-008 JUL 05 Body - Convertible Top Tonneau Cover Won't Latch 04-08-44-023C JUL 05 Audio System - Numerous Radio/CD Player Concerns 05-08-42-009 JUL 05 Lighting - Front Park Lamps Turn Signals Int. Inop. 04-08-48-001B JUN 05 A/C - Broken Rear Window Defogger Grid Detection 05-08-44-019 JUN 05 Audio System - Station Presets Change/No Audio 05-05-25-004 JUN 05 Brakes - Revised Brake Control Module Replacement 05-03-16-001 MAY 05 Computers/Controls - DTC U1000 Explanation 05-08-42-007 MAY 05 Lighting - Headlamp Seal Assembly Torn 05-03-10-004 APR 05 Tire Monitor System - Tire Mounting/Dismounting Cautions 00-08-46-002A APR 05 OnStar(R) - Cellular Antenna Replacement Parts 05-08-42-004 APR 05 Lighting - Apparent Headlamp Hazing or Shadows 05-03-08-004 MAR 05 Suspension - Revised Front/Rear Ball Joint Torque Specs. 05-08-66-002 MAR 05 Body - Rear Hatch Exterior Release Switch Operation 03-05-24-001A MAR 05 Brakes - Wheel Cylinder Inspection Guidelines 05-08-49-005 FEB 05 Instruments - Inside/Outside Temperatures Don't Match 00-08-46-003B FEB 05 Instruments - GPS System Performance Degradation 05-08-44-004 FEB 05 Audio System - Various Door/Speaker Concerns 05-08-66-001 FEB 05 Body - Rear Hatch Inoperative With Key 04-06-03-016 DEC 04 Battery - Specification Label Clarification 04-07-29-003B DEC 04 M/T - Normal Shift Lever Movement 04-08-50-018 DEC 04 Interior - Driver/Passenger Seats Inoperative 04-08-44-022 NOV 04 Audio System - CD Eject Button Sticks 01-01-38-006D SEP 04 A/C - R-134a System Flushing Procedures 04-08-68-002 SEP 04 Cruise Control - Increasing Set Speed 01-03-10-009A JUL 04 Wheels - Plastic Wheel Nut Covers Loose/Missing 02-06-03-010A JUL 04 Battery - Parasitic Drain |
Check to see if there was a problem with the steering lock. I needed to replace mine because of a defect in the column.
Thanks for all your replys!
How can I see the steeringlock problem if it's stil exists? |
Originally Posted by greenbeauty
(Post 1580296537)
There will be people who say to stay away from a first model year vehicle (the 2005's were the first year of the 6th generation) like this one, and yeah, there were a few problems during this year but I know a bunch of 2005 C6 owners who have gone problem free and couldn't be happier.
Great colour too. Good luck with the test drive. |
Thnx man :)
I'm from the Netherlands, unfortunately here are not much corvette's..hehe Btw.. I'm still in a really (little) doubt about buying the C5 Z06!.. Also 405HP, and a really sporty look.. But it's just missing the luxoury and options that the c6 has.. :D How about the riding on the road? which one is better for daily use? |
(Post 1580296645)
Thnx man :)
I'm from the Netherlands, unfortunately here are not much corvette's..hehe Btw.. I'm still in a really (little) doubt about buying the C5 Z06!.. Also 405HP, and a really sporty look.. But it's just missing the luxoury and options that the c6 has.. :D How about the riding on the road? which one is better for daily use? For performance - the C5 Z06 For a daily driver - the 2005 C6 |
(Post 1580294224)
Tomorrow I'm going to look at a corvette c6 from 2005 with 30.000 miles on the clock :) The car is MANUAL shifted. Are there common things to watch out for when I do the testdrive? I also read some things about the gearbox that it's a weak thing with the 2005 models.. I hope someone can post some things to check when I do my testdrive tommorow! This is the car: http://img820.imageshack.us/img820/9784/70719473.jpg Thanks! The car you are interested in has different color headlamps compared to the body color. IMHO never a good sign :ack: Fred |
It's less about the year, and more about the previous owner and whether s/he took good care of the car.
I'd rather buy a well maintained 2005, than a 2008 that's been beat on. All being said, I got my 05 from a guy who took REALLY good care of it, and I couldn't have been happier with the purchase! |
Originally Posted by MDPD23
(Post 1580296528)
Originally Posted by Polar Jet
(Post 1580296591)
Great colour too. Good luck with the test drive. Yep, another problem free 2005 owner:thumbs: MY car has 34K miles on it. I have had to replace the fuel vent solenoid and it took me less than 30 mins to do it myself. The DIY thread is here http://forums.corvetteforum.com/c6-c...49-w-pics.html BTW you can easily bypass the skip shift (Computer Aided Gear Selection or CAGS) with a smart fuse. Check out this thread....I did this and it is great:thumbs: http://forums.corvetteforum.com/c6-c...2013-cags.html Check the tires. At 30k miles they are either worn out or have been replaced. To replace tires your looking at $1,500 +/-. Even if the tires are newer, turn the wheels to the left or right lock and look for excessive ware on the inside of the tread. The tires are so wide you cannot tell with out turning the wheel. |
you get buy a CAGS shift bypass for about 18 dollars and get rid of that 1-4 shifting. I bought one for my 05 (fuse type) it installs in about 5 minutes. Then you wil REALLY enjoy your ride
Originally Posted by 05LemansBLue
(Post 1582700817)
you can: buy a CAGS shift bypass for about 18 dollars and get rid of that 1-4 shifting. I bought one for my 05 (fuse type) it installs in about 5 minutes. Then you will REALLY enjoy your ride
Love mine... Ditto a previous post re the different color headlamp surround...question that.
So did OP buy the car???
